What Oil Should I Use in My Fip Top Oilers?
Posted: Fri Dec 22, 2023 12:58 pm
by BLB27
What oil should I use in my fip top oilers on my 1927 coupe?
Re: What Oil Should I Use in My Fip Top Oilers?
Posted: Fri Dec 22, 2023 1:05 pm
by Humblej
Any engine oil will do.
Posted: Fri Dec 22, 2023 1:09 pm
by JBog
I use bar chain oil. It sticks better.
Posted: Fri Dec 22, 2023 1:30 pm
Maybe so BUT, does it migrate better ?
Posted: Fri Dec 22, 2023 1:58 pm
by Tadpole
Anything that lubricates can get the job done, I use maple syrup because I like the smell.
Posted: Fri Dec 22, 2023 2:26 pm
by Dallas Landers
I use CBD oil. Eats more gas but the front end is calm with no shaking.
Just funnin. I use bar and chain oil also.
Posted: Fri Dec 22, 2023 2:49 pm
by havnfun
Any motor oil, it takes on a rebuilt front axle assembly overnight to lubricate the spindle bushings top and bottom. You should see oil spots under the spindle bolts or the lubricant isn’t lubricating the bottom bushing.
Posted: Fri Dec 22, 2023 3:10 pm
by tvw
Dallas Landers wrote: ↑Fri Dec 22, 2023 2:26 pm
Good one!
I use any motor oil which usually means 0 or 5w something, which really runs thru fast. I bet the bar oil works good tho.
Posted: Fri Dec 22, 2023 3:46 pm
Chain bar lube or 600W is my go to most of the time.
Posted: Fri Dec 22, 2023 5:14 pm
by Bill Anziani
I use the 600 weight also
I refill the oilers about twice a week
Posted: Fri Dec 22, 2023 5:22 pm
by Joe Bell
Chainsaw bar oil, nice and sticky.
Posted: Fri Dec 22, 2023 5:30 pm
by Charlie B in N.J.
I concur with the majority: chain saw bar oil.
Posted: Fri Dec 22, 2023 6:51 pm
I have 2 chain saws I use here on the place and the bar and chain oil is the best oil to use. It doesn’t take a lot and the stickiness and weight helps it stay in place.
Posted: Fri Dec 22, 2023 8:45 pm
by Art M
Ii have been using chainsaw oil for about 3 years. I didn't know anyone else who uses it until now. I apply oil every 100 miles as recommended in literature.
Art Mirtes
Posted: Sat Dec 23, 2023 1:39 pm
by Roger Byrne
I agree with the majority view and use bar oil on all of them . . . EXCEPT on the spindle oilers. If the bushings are new/tight, I use regular engine oil (10-30). If they are worn, then they get bar oil too.
Posted: Sat Dec 23, 2023 2:13 pm
by Rich Eagle
I often use Amsoil Synthetic R&O, AW gear and bearing oil ISO-680 (RPC). It is thick but flows well. I bought it to use in my Warford and use it in T rear ends as well as my '23 White trans and rear end. I like it but also use Pennz 10-30 sometimes.
Posted: Sat Dec 23, 2023 8:52 pm
by Craig Leach
I have found gear oil to work well, I have even saved it when I change the rear end oil.( if it's clear of metal flakes) the most important
thing is to oil them as most don't seem to do it very often! Don't forget all the other lube points. For some reason I'm always short of bar oil.
Merry Christmas all.
Craig.
