Early vs late rear end carrier?
Posted: Wed Feb 07, 2024 4:44 pm
by Karl Von Neumann
Just curious I have 2 rear end carriers is one just a earlier version which is which?
Re: Early vs late rear end carrier?
Posted: Wed Feb 07, 2024 5:49 pm
by Model T Mark
The one with the studs is earlier. The late ones have bolts all the way through both sides.
Posted: Wed Feb 07, 2024 5:58 pm
by Mark Gregush
The lip that the thrust washers ride in is really worn and undercut on both. The thrust washer would have been held in place with two pins. Looks like the pins sheared, allowing the steel thrust washers to cut into the flange.
Early or late, they both fit/work the same, only difference, the early needed a tie wire between the 3 studs and late bolt type used cotter pins.
Posted: Wed Feb 07, 2024 6:11 pm
by Karl Von Neumann
So what year is the change over?
Posted: Wed Feb 07, 2024 8:35 pm
by DanTreace
Bolt began being used in 1922 instead of stud.
Posted: Thu Feb 08, 2024 1:35 pm
by signsup
I prefer the early rear end carrier, myself.
What? Oh, you mean a Model T?
Never mind.
Posted: Thu Feb 08, 2024 4:25 pm
by RVA23T
The rear end above is just someone else's problem.
