Crankshaft journal radius
Posted: Mon Feb 12, 2024 3:55 pm
by Dave1
What is the recommended radius for the ends of the bearing journals when grinding. I have a coupe of cranks on hand, it seems the last fellows that ground had different ideas.
Dave
Re: Crankshaft journal radius
Posted: Mon Feb 12, 2024 4:43 pm
by Kerry
Usually what the grinder does, he is not going to change any angles of his stone for just one T crank if it differs from what he is using. ie, scat cranks have a larger radius and usually have to scrape the babbitt some to clear.
Posted: Mon Feb 12, 2024 5:35 pm
by t-time
The 1926 Ford print shows the main journals 5/64-1/8 radius and rod journals 7/64-9/64 radius. The larger the radius the stronger and less chance of cracks developing.
Posted: Mon Feb 12, 2024 6:50 pm
by J and M Machine
We try and keep them as big as possible. At least 3/32"
Problem is after 100 years and bad machine shops most often nothing left.
BTW: since everyone else is advertising now on the forum:
https://www.jandm-machine.com/grinding.html
Posted: Mon Feb 12, 2024 8:48 pm
by Dave1
Gotcha, thanks
