Reamer lubricant, water- or oil-based?
Posted: Tue Feb 13, 2024 9:39 am
by Mark Nunn
I have always used oil-based when reaming. I'm reaming valve guides and decided to try water based. The company I work for uses water based in our cutting machinery. I'm not happy with progress so far. I ruined my reamer when I hit a hard spot in the casting. Before I finish. What do you all prefer and why?
Re: Reamer lubricant, water- or oil-based?
Posted: Tue Feb 13, 2024 10:13 am
Old-fashioned oil-based thread cutting oil ought to work.
If you hit a sand inclusion in the block, it wouldn't matter much what lubricant you used.
I'd guess water-base lubricants are meant for modern, insert-type cutting tools. Tool steel cutters probably work best with an oil base lube.
Posted: Tue Feb 13, 2024 2:15 pm
by Dan McEachern
Cast iron= dry.
Posted: Tue Feb 13, 2024 5:37 pm
by Art M
Three years ago I reamer the valve guides dry and had no problem. Definitely don't use motor oil. It's important to control the reamer alignment.
Art Mirtes
Posted: Tue Feb 13, 2024 5:52 pm
by jiminbartow
Our machinist used water soluble oil. Oil that would mix with water. It would circulate through the machine and pass through a strainer. It went much farther and was just as good as regular lubricating oil.
Posted: Wed Feb 14, 2024 8:23 am
by Mark Nunn
Dan, Scott Conger told me the same thing. I was unaware that cast iron should be dry. Thank you for your input.
Posted: Wed Feb 14, 2024 8:36 am
by Mark Nunn
Well there it is in my Machinery's Handbook. Cast iron should be dry. I should have looked there first. Thanks to all.
Posted: Wed Feb 14, 2024 5:53 pm
by tiredfarmer
Do you use cutting oil when reaming bronze bushings or can you ream them dry?
Posted: Wed Feb 14, 2024 9:34 pm
by Mark Nunn
Bronze should have soluable oil.
Posted: Thu Feb 15, 2024 7:44 am
by tiredfarmer
OK I'm not very bright. What is soluable oil?
Posted: Thu Feb 15, 2024 9:39 am
by Mark Nunn
Soluble Oil is a chlorine-free, water miscible metalworking fluid designed to emulsify easily and form a long-lasting, stable emulsion when mixed with water
Posted: Thu Feb 15, 2024 9:51 am
by jiminbartow
Water soluble oil. Oil that mixes with water. Designed for providing lubricant and cooling properties to machine work that would overheat without it. Makes the lubricating oil thinner and allows it to go farther making the job more economical.
Just one example. There are all types of brands.
Posted: Thu Feb 15, 2024 5:49 pm
by tiredfarmer
OK Thanks a lot for telling an old dummy guys. I always learn something on this forum.
Posted: Fri Feb 16, 2024 9:42 am
by greenacres36
I agree usually cast-iron is cut dry. But sometimes I would use something like WD-40 or PB blaster.
