It runs ... just poorly on magneto
Posted: Sun Feb 25, 2024 12:12 pm
by vping
Starter problems solved by cleaning and adding a ground strap.
Starts and runs great, and I can rev up rpms and sounds good.
When I switch to magneto it runs poorly and when I rev the rpms, it sputters.
I cleaned the mag pickup which did have fuzz on it and jiggled ignition key (no change) and it still runs poorly. Back to battery and it runs great.
What are my next steps to check?
Re: It runs ... just poorly on magneto
Posted: Sun Feb 25, 2024 12:19 pm
Check magneto output voltage with an analog meter.
When confirmed too low, do an in car magnet recharge.
Posted: Sun Feb 25, 2024 12:21 pm
by vping
Yeah I read that somewhere. Exactly how do I check? 1 lead to pick up and 1 to ground?
Also what if I only have a digital meter?
Posted: Sun Feb 25, 2024 12:28 pm
vping wrote: ↑Sun Feb 25, 2024 12:21 pm
1 lead to post, one to ground.
Digital meters will wack out from the coils operating. They are useless.
by vping
I'm running a dizzy. Does that change anything?
Posted: Sun Feb 25, 2024 12:34 pm
vping wrote: ↑Sun Feb 25, 2024 12:28 pm
Magneto puts out AC power. Your dizzy uses DC.
Your magneto wont run dizzy. The only use would be to rectify the output to charge the battery.
Posted: Sun Feb 25, 2024 12:40 pm
by vping
Thanks for all the responses and patience John. Explain that last sentence please. Can I run on just battery?
Posted: Sun Feb 25, 2024 12:50 pm
If you have a generator motor(19-27), the generator keeps the battery charged & yes, you run on battery only with a dizzy.
If you had an earlier motor & needed to keep the battery charged, you could convert your magneto to DC voltage output to keep the battery charged.
Posted: Sun Feb 25, 2024 1:07 pm
by vping
Got it. Ok so far so good then. I think I ran out of gas now because it won't start lol. Thanks for all of your help
