Quick Poly?
Posted: Wed Mar 13, 2024 11:53 am
by thom
Can anyone tell me about, or give a link about repairing (temporarily) wood spoke wheels with something called Quick Poly? Thanks.
Re: Quick Poly?
Posted: Wed Mar 13, 2024 12:04 pm
by RajoRacer
A "temporary" repair to a wood wheel is most likely a bad idea !
Re: Quick Poly?
Posted: Wed Mar 13, 2024 12:09 pm
by Kaiser
A wheel that needs repaired to be drivable should be rebuilt properly, a repair with 'Quick Poly' or other so-called wood-rot-stoppers is only acceptable for static display.
Driving with "Fixed" wheels is going to get you or others hurt, don't do it.
Re: Quick Poly?
Posted: Wed Mar 13, 2024 12:32 pm
by TRDxB2
Kwik Poly is no longer made
Not sure what kind of repair you need to make - perhaps it would be better to show & explain the issue.
Product evaluations https://www.rotdoctor.com/test/penetration.html
Re: Quick Poly?
Posted: Wed Mar 13, 2024 12:56 pm
by Jerry VanOoteghem
I believe West Systems makes a similar product.
However, as others suggest, it's generally not a good idea. Please post pictures of your problem. For any of us to encourage you to do such a repair would be irresponsible and possibly unsafe to you without any knowledge of the current wheel condition.
Re: Quick Poly?
Posted: Wed Mar 13, 2024 6:27 pm
by jiminbartow
Www.Abatron.com. I agree with everyone here but you have to be the judge. “LiquidWood” 2 part epoxy is the equivalent of Kwik Poly. Mix the 2 parts and paint it on with a paint brush until the wood will take no more. It will cure to a very hard material deep in the wood. I have been using it on rotten window sills and porch parts of my house for 40 years. Any indentations can be filled with “WoodEpox”. Be careful.
Re: Quick Poly?
Posted: Wed Mar 13, 2024 9:51 pm
by TWrenn
Git Rot may be a suitable substitute for Quik Poly also. Great stuff, been around for decades. It saved many a bad area on my wooden Chris Craft back in the 70's.
Re: Quick Poly?
Posted: Wed Mar 13, 2024 11:51 pm
by Dan McEachern
Re: Quick Poly?
Posted: Sat Mar 30, 2024 6:59 pm
by CraneJon
Had a front wheel fail once. Advice...Go see Mr Stutzman in Ohio and have your wheels rebuilt correctly for the next 100 years!
