Driveshaft bushing question
Posted: Thu May 30, 2019 8:31 pm
by Belliott3
I have a bit of a problem. While rebuilding my rear axle and two piece driveshaft, I installed a new bushing and now the driveshaft won't fit through. The driveshaft is brand new and the bushing fit over it when I first took it out of the package, but the I.D. of the bushing compressed slightly when I installed it using the correct driver. Chaffin's rebuild book says that you can ream out the center to get a better fit, but I can't seem to find any vendors that sell a 1" reamer; they all sell the facing reamer but not the center one. Any suggestions?
Re: Driveshaft bushing question
Posted: Thu May 30, 2019 8:41 pm
by Bill Crosby
Bill. Purchase an adjustable reamer from MSC.com, McMaster.com or off the internet and hand ream a little at a time or take it to your local machine shop. Smaller shops are more likely to help, Big shops are to busy. If you need more help send me a pm and I can talk you through the job. It's not hard to do just take your time.
Bill
Posted: Thu May 30, 2019 9:01 pm
Bill C, Could a brake cylinder hone be used in this application? Much cheaper for a one time use.
Posted: Thu May 30, 2019 9:19 pm
by Bill Crosby
I have always used a reamer, It's muck quicker and more acurate. The hone shown would work as long as you only need to remove a small amount of material, go with slow RPM to keep it round and stroke it in and out to keep it straight. Use ATF as a cutting oil and It will flush away the removed material, keep the honing stones wet. Check It often so you don't get too big. Clean it very well to remove any small pieces of grit from the stones or It will ware on the drive shaft. Bill
