Refurbishing Steering Wheel
Posted: Fri Mar 22, 2024 11:56 am
by JBog
Does anyone have any tips on refurbishing the old rubber black steering wheels? Mine has some cracks and is generally worn looking.
Re: Refurbishing Steering Wheel
Posted: Fri Mar 22, 2024 12:36 pm
JBog wrote: ↑Fri Mar 22, 2024 11:56 am
Try these
https://www.mtfca.com/discus/messages/8 ... 1240573989
https://www.mtfca.com/discus/messages/1 ... 1301421083
https://www.mtfca.com/discus/messages/7 ... 1501160405
Posted: Fri Mar 22, 2024 7:30 pm
by George House
Thank you Frank !.. You’ve dug up some excellent advice ! I’ve even had that question. Including fastening back together a broken Fordite rim. Now to put your good advice to work
Posted: Fri Mar 22, 2024 8:01 pm
by George Hand
I read this including the 3 previous archived posts, I did not see what material was used to fix cracks, maybe I missed it. George
Posted: Fri Mar 22, 2024 8:13 pm
An old friend restored A wheels with bowling ball epoxy. (used to repair chipped balls)
Posted: Fri Mar 22, 2024 11:16 pm
by JBog
George Hand wrote: ↑Fri Mar 22, 2024 8:01 pm
I wonder if you could use that paint on rubber, Flex Seal, that's always on tv?
Posted: Fri Mar 22, 2024 11:41 pm
I used Flex Steel Paste to restore a 1913-22 switch base that was made of hard rubber. It blended in so well you cant tell & its hard. It may not be the best product to use the on the steering wheel, but a possibility. I did have a Fordite wheel in the past & think it would work. They have a smaller can now. Haven't used their liquid yet
Posted: Sat Mar 23, 2024 11:35 am
If it's cracked up, why not replace it - Bob's Antique Auto Parts was reproducing 16" black rims a number of years ago - I might still have one in stock.
Posted: Sat Mar 23, 2024 12:54 pm
by jiminbartow
Fill the cracks by pressing in JB Weld. Smooth as much as possible by gently smoothing with a wet finger before it sets up. Spray with Rustoleum gloss black Appliance Epoxy. When good and dry, Use Meguiar’s rubbing compound to polish to a mirror shine. Jim Patrick.
Posted: Sat Mar 23, 2024 2:56 pm
The A steering wheel had a steel core inside the Fordite. No problem patching it up. However, the T steering wheel does not. It would be dangerous to try to repair any wheel which has a piece broken out of it. For external cracks around the edge, repair would be OK. Remember you might need the steering to work when going around a curve. Better safe than dead or severely injured.
Posted: Sat Mar 23, 2024 5:55 pm
by Oldav8tor
I'm with Norman - Lacking a metal core I suspect at some point when it is most inconvenient the wheel might break in your hand. I'd vote for replacement. Fordite was not one of Henry's successes.
Posted: Sat Mar 23, 2024 8:52 pm
by jiminbartow
Even if it were to break, you still have four sturdy steel arms of the spider to steer with. Not a big deal.
Posted: Sat Mar 23, 2024 10:23 pm
by tselliott
I restore the Fordite steering wheels by sanding and polishing. They always come out great. I recently restored one and had it hanging from the garage door tracks and it fell and broke. It didn’t break in two but split open so it was not a closed circle. I used some JB weld epoxy and clamped it together. It seems as strong as it was before it broke. You can see the crack but it still seems strong and usable.
Posted: Sun Mar 24, 2024 5:30 pm
by hah
Ahhh! Live on the edge. Repair it! Use SEM's product. 50 second glue or panel bonding adhesive. Look at the sem's product sheets to determine application.
