Everything quit
Posted: Tue Mar 26, 2024 4:05 pm
by OldTimerTT
Hello, After backing out my TT to do some spring maintenance I went to start it up to take a ride. It started and stalled, when I went to start it again I had nothing. No coils buzzing, starter didnt spin engage.....I have 6volt power to it all but it all is dead. I even tried to put a jumper form the batt to the starter, nothing! Ideas?
Re: Everything quit
Posted: Tue Mar 26, 2024 4:16 pm
How long has it been parked? Maybe the battery only had enough charge left for one start. Try putting a charger on it for a while and see if it works. Otherwise, something has disconnected between the battery and the starter switch. I would check the terminals for corrosion.
Re: Everything quit
Posted: Tue Mar 26, 2024 4:22 pm
by kmatt2
First check and clean the battery to frame ground cable. If still no starter spin add a auxiliary ground cable from engine to frame. After that check the battery for an internal short or problem under load. You may need some new battery cables or a new battery.
Re: Everything quit
Posted: Tue Mar 26, 2024 4:52 pm
Battery load tester.
No car owner should be without one.
Re: Everything quit
Posted: Tue Mar 26, 2024 5:39 pm
by Charlie B in N.J.
Do you have a fuse in the main feed line? If so check it.
Re: Everything quit
Posted: Tue Mar 26, 2024 6:02 pm
by schwabd1
Although it was my "modern" car, I had the same situation about 10 years ago. No battery problems, drove the car to work, went to leave for lunch, 100% dead...nothing, Turned out one of the plates in the battery dropped and did a total short internally. A new battery did the trick..
Re: Everything quit
Posted: Tue Mar 26, 2024 6:35 pm
by vping
speedytinc wrote: ↑Tue Mar 26, 2024 4:52 pm
Recommendations on which one to get?
Re: Everything quit
Posted: Tue Mar 26, 2024 6:59 pm
vping wrote: ↑Tue Mar 26, 2024 6:35 pm
Mine is an old American made unit.
ebay : "6V 12V Car Battery Load Tester Voltmeter 100Amp Analyzer 5 Seconds Fast Test"
I would go with this king of analog tester over a cheaper electronic unit.
Re: Everything quit
Posted: Tue Mar 26, 2024 8:24 pm
Have you checked the water in the battery? One time we were out camping and a car near us couldn't start their car. The water level in the battery cells was very low. We added water and without even charging the battery, it started.
Re: Everything quit
Posted: Tue Mar 26, 2024 9:46 pm
by michaelb2296
Ground issue. Harbor Freight for a battery tester.
Re: Everything quit
Posted: Tue Apr 09, 2024 7:41 am
by MariaDenesik
All good now?
Re: Everything quit
Posted: Tue Apr 09, 2024 11:54 am
by jsaylor
I highly recommend the Harbor Freight Centec load tester. It will give you quick look at your battery condition.
Re: Everything quit
Posted: Tue Apr 09, 2024 1:30 pm
by Moxie26
Were you able to start the truck on magneto?.... Strong possibility of your cutout points stuck together and drained the battery .
Re: Everything quit
Posted: Tue Apr 09, 2024 2:29 pm
by John Codman
schwabd1 wrote: ↑Tue Mar 26, 2024 6:02 pm
You were lucky. The battery in my '82 Oldsmobile Station Wagon did the same thing and the battery exploded.
Re: Everything quit
Posted: Tue Apr 09, 2024 7:08 pm
by Michael Peternell
Dead short. Check your ground cable.
Re: Everything quit
Posted: Wed Apr 10, 2024 3:25 am
Had the same thing today. I was going out to fuel up for a tour stating tomorrow, hit the starter switch and killed everything. Previously we had been chasing a slow starter problem, which was cured by taking the switch apart, cleaning all the contacts and re fitting same. When the ground lead at the battery was hooked up again, slow starter problem went away. Beauty!
It turned out to be that battery ground terminal. The nut and bolt in the clamp were tight, but somehow the terminal was not tight on the battery pole.
