TT Auxiliary Trans
Posted: Mon Jun 03, 2019 6:59 pm
by desertexplorer
I recently acquired a Lincoln over/under trans for my TT truck but it's missing the part (or parts) to mount the shift tower. Without it I have no way of mounting the shift tower to the torque tube. The photo shows the tower and shift linkage that I have.
Anyone know what parts I need to mount this?
Thanx everyone!
Re: TT Auxiliary Trans
Posted: Mon Jun 03, 2019 7:06 pm
by A Whiteman
Probably just a large "U" bolt.
Posted: Mon Jun 03, 2019 7:07 pm
by Dropacent
Just a big U-bolt, Wallace. It’s heavier than a muffler clamp bolt, but that may work for you. The right one would be pretty easy to make. There are a lot less shifters than transmissions that survived. Nice piece !
Posted: Mon Jun 03, 2019 7:26 pm
by 46woodduck
A rear axle U-bolt would probably work or you could probably just use a piece of threaded rod and bend your own.
Posted: Mon Jun 03, 2019 7:30 pm
by desertexplorer
I tried today clamping a u-clamp but you can't get it tight enough. When you go to shift there's a lot of torque from the shift knob and the tower slides left and right on the torque tube. Also, without the part the tower isn't high enough off the torque tube and the shift linkage binds. Not really sure what I'm missing...
Posted: Mon Jun 03, 2019 7:54 pm
by RalphS in NE Oregon
Wallace,
I have a Lincoln like that. You are missing a heavy casting that goes under the torque tube and bolts to the shifter with a bolt on each side. Mine also has a diagonal brace on each side that connects to the bolt that connects the two radius rods to the torque tube. This is what takes all the shifting load. Could your braces have been cut off? No time tonite but I will try to scrape the grease off tomorrow and get a picture of the shift tower in place.
Ralph
Posted: Mon Jun 03, 2019 8:06 pm
by Dropacent
Yes Wallace, what Ralph just posted is spot on ! I had to look at mine. You are missing a small casting that has ears to connect to the radius rods. If you need a sketch, just ask. Looks like a 5/16” u bolt, too. If you can’t make it, Hank in Tennessee sure could.
Posted: Mon Jun 03, 2019 8:07 pm
by Dropacent
Oh gosh, now original smith Is going to see another zerk fitting and go nuts again !
Posted: Mon Jun 03, 2019 8:38 pm
by Dallas Landers
Tim, we all seen it but we didnt say anything!
Posted: Mon Jun 03, 2019 8:40 pm
by Dropacent
DAG NABBIT!
Posted: Mon Jun 03, 2019 8:45 pm
by Dallas Landers
I would just put floor boards over it and your good.
Posted: Mon Jun 03, 2019 9:52 pm
by Ruxstel24
Stick a hose on it and run it up towards the fuel tank !!
Posted: Mon Jun 03, 2019 11:14 pm
by desertexplorer
Wow, I get back from my shop and get responses with photos even, that was quick!
I see the part that I'm missing, my guess is thst whoever removed the trans and shifter assy just removed the 2 top bolts and left the rest bolted to the driveshaft tube. My only option is obtaining a part to have a casting made or fab one up. A sketch of the part would be great, Thanks! (nice looking zerk too!)
