What the...?!!
Posted: Thu May 09, 2024 1:43 pm
Nothing about how to apply for authorization? :D
Re: What the...?!!
Posted: Thu May 09, 2024 1:57 pm
by TWrenn
Never seen this one before!
Re: What the...?!!
Posted: Thu May 09, 2024 2:19 pm
by mtntee20
Steve, If they are YOUR messages, why does the forum require authorization? I would recommend contacting Admin.
Re: What the...?!!
Posted: Thu May 09, 2024 2:43 pm
by ThreePedalTapDancer
Delete some of your inbox messages it probably is telling you your inbox is full. If it’s full it won’t allow you to read messages until you make more room by deleting old messages. If full, incoming messages will be “on hold” until you allow more room.
Re: What the...?!!
Posted: Thu May 09, 2024 4:08 pm
My screens were a bit different, possibly because I had messages
To see and/or delete
Click on PRIVATE MESSAGES
The inbox with message is return if you have any
Check the ones you want action - example Delete Marked
Follow screen instructions from then on
Re: What the...?!!
Posted: Fri May 10, 2024 1:33 pm
OK, so I managed to find my stored messages. The box was 100% full so I picked a few to delete. Now, there they sit with check marks after them. But I don't find a Delete button anywhere. How can I get rid of the ones I checked?
Re: What the...?!!
Posted: Fri May 10, 2024 2:48 pm
After you select/check messages to delete, go to right side near bottom, push for drop down menu, select “delete marked”
Re: What the...?!!
Posted: Fri May 10, 2024 4:41 pm
Then click on the GO icon
