Copper intake/exhaust rings
Posted: Fri May 17, 2024 1:12 pm
by Belliott3
Are the crushable copper intake/exhaust rings reusable? I’m thinking not, but I’d like to be certain.
Re: Copper intake/exhaust rings
Posted: Fri May 17, 2024 1:32 pm
by George House
I wouldn’t - once they’ve lost the designed utility of being crushed by manifolds…. I do reuse cotter keys tho’
Posted: Fri May 17, 2024 2:10 pm
by Jerry VanOoteghem
Not reuseable.
Posted: Fri May 17, 2024 2:33 pm
by jiminbartow
No. They are designed to assume the irregularities (such as rust pits) of the surface they are pressed into. If they are rotated or transferred to a different port, the surface changes and they can no longer seal properly.
Posted: Fri May 17, 2024 2:51 pm
by Belliott3
Thanks for the confirmation: I thought they were one and done!
Posted: Fri May 17, 2024 3:10 pm
by Les Schubert
I have reused them when I’ve had do repairs on a road trip. The important thing is to retorque them HOT on reassembly and possibly more than once
Posted: Fri May 17, 2024 7:58 pm
by Ed Baudoux
If they're not seriously deformed, anneal them by stringing them on a piece of wire, hearing them red with a torch, and quenching them in water. They'll be soft enough for reuse.
Posted: Fri May 17, 2024 11:11 pm
by Steve Jelf
It may be overkill, but I smear some hi-temp RTV on them, especially if the engine surface has any pitting.
