Viton needle for Holley S Carburetor
Posted: Wed May 22, 2024 10:50 am
by Rod
Does anyone have a source for a Viton tipped Needle? It’s for a 1913 Holley S carburetor. It measures 7/8” long by 1/4” wide. I don’t need the seat, only the needle. Also any gaskets out there?
Re: Viton needle for Holley S Carburetor
Posted: Wed May 22, 2024 1:21 pm
by Mark Nunn
Have you checked with Scott Conger? I don't know if he makes needles for the S but it is worth asking. Search for him using the "Extra Quick Links" button above right.
Posted: Thu May 23, 2024 6:23 pm
by ChrisB
No R in Viton.
Viton rubber is a type of Fluoroelastomer that has a highly unique molecular structure and composition. Manufactured from a combination of hexafluoropropylene (HFP) and vinylidene fluoride (VDF), resulting in material with exceptional chemical resistance, high-temperature stability, and excellent mechanical properties.
When I worked for Chrysler back in the 70s there was a recall that was related to them not using Viton in an accelerator pump instead of rubber that cost them millions.
Posted: Thu May 23, 2024 9:51 pm
by Steve Jelf
If my NH experience is any indication, Viton tip needles sometimes stick. That's why I prefer original type needles. If Scott makes a float valve for your carburetor, that's the way to go.
Posted: Thu May 23, 2024 10:13 pm
by tdump
Ditto, those tips tend to hang for some reason.
