How much clearance?
Posted: Wed Jun 19, 2024 7:00 pm
by michaelb2296
How much clearance should there be between the rod cap and the crankshaft lobe? Skat crank has tight tolerances!!! Old cranks dont have this issue… lots of slop between journal lobes.
Re: How much clearance?
Posted: Wed Jun 19, 2024 7:16 pm
by Kerry
Ford specs are the crank is 1.505" and rod is 1.5" wide.
Posted: Wed Jun 19, 2024 7:21 pm
by michaelb2296
How do i sand .0025 off each end? Ford used a big damn file on the caps!
Posted: Wed Jun 19, 2024 7:24 pm
by Kerry
Is the rod turning or binding?
Posted: Wed Jun 19, 2024 7:27 pm
by michaelb2296
Nope! New babbit. Not turning… super tight but does fit around the journal
Posted: Wed Jun 19, 2024 7:58 pm
by Kerry
OK, usually it is the fillet cut that is tight, not cut deep enough to clear the fillet on the edge of the crank journal, but if you think it is too wide then rub the rod on a flat piece of glass with a sheet of about 320 sand paper. Run the rod bearing in with time saver.
Posted: Wed Jun 19, 2024 8:32 pm
by Joe Bell
I would rather have a large radius than a small one, less chance of breakage.
Posted: Wed Jun 19, 2024 9:28 pm
by JTT3
Amen Joe. As stated time saver will be your friend in fitting the rods on the journal, yellow 60 grit
