motor number
Posted: Fri Jun 07, 2019 2:29 pm
by jrichardso
Where is the stamped motor number located on the motor?
Re: motor number
Posted: Fri Jun 07, 2019 2:34 pm
by Dallas Landers
Just above water outlet on left side of block.
Re: motor number
Posted: Fri Jun 07, 2019 2:36 pm
by jrichardso
Thank you.
Re: motor number
Posted: Fri Jun 07, 2019 2:37 pm
by jsaylor
Left side of engine just above the water outlet.
Re: motor number
Posted: Fri Jun 07, 2019 4:15 pm
by Hap_Tucker
The above is true for most Model Ts -- but they were in other locations for mid-1912 and earlier engines.
Your profile says you have a 1917 -- so the information above is great for you. Welcome to the forum. And your profile says you are in Lafayette, Indiana. That places you about 2 hour 16 min according to Google Maps from Richmond, IN. The big Model T get together has been going on yesterday and today. And it has one more day on Sat 8 Jun. I would encourage you drive over (recommend the modern car as it sounds like you recently acquired the T). For additional details please see:
viewtopic.php?f=2&t=4306
Good luck with your car!
Respectfully submitted,
Hap l9l5 cut off
Re: motor number
Posted: Fri Jun 07, 2019 5:35 pm
by jrichardso
Thanks everybody for the picture & info
Re: motor number
Posted: Fri Jun 07, 2019 6:42 pm
by Dan Hatch
Water inlet. Water outlet is on the cylinder head. Dan
Re: motor number
Posted: Fri Jun 07, 2019 7:19 pm
by Dallas Landers
Dan is correct. In the bottom out the top.
