Transmission Band Lining
Posted: Fri Jun 28, 2024 6:48 am
by Moxie26
Came across this picture of questionable material used for band lining...... Woven textile, kevlar, wood, modern auto trans molded ???????
Re: Transmission Band Lining
Posted: Fri Jun 28, 2024 6:18 pm
by TWrenn
Pretty sure it ain't Kevlar. I'm voting for wood even tho I've never had any experience with wood bands
Posted: Fri Jun 28, 2024 6:24 pm
by Kevin Pharis
Looks like there might be a faint glimmer of a few copper strands… that would make this Model A brake lining. Word on the street is this stuff is hard on drums. Others may have personal experience…
Posted: Fri Jun 28, 2024 7:03 pm
by 23ford
Looks like caterpillar band lining material that was popular in the 1970's.
Felix Graves promoted this and sold to several people. My 21 RPU is running this
Posted: Fri Jun 28, 2024 7:16 pm
by Daisy Mae
Kevin, same thought, looked like brake band material to me
Posted: Sat Jun 29, 2024 9:17 am
by Moxie26
All three bands as found
Posted: Sat Jun 29, 2024 9:35 am
by jiminbartow
With what appear to be angled saw cuts on the edge, I would guess it is an oil soaked wood band. I don’t think such saw cuts would exist in softer band material. Also, the lack threads or frays indicate it is not any kind of woven material.
Posted: Sat Jun 29, 2024 9:38 am
by TWrenn
Moxie26 wrote: ↑Sat Jun 29, 2024 9:17 am
That brake band looks mighty thin...I'm assuming your plan is to change 'em all out anyway and just wanted to show these first.
Posted: Sat Jun 29, 2024 5:18 pm
by jsaylor
I ran some of that hard bonded lining back in the 60's. Its was hard on the drums. I changed to Kevlar when it came out. I still have the set up on a shelf. I have not had success removing the bonded stuff from the bands.
Posted: Sun Jun 30, 2024 12:37 pm
by jiminbartow
You can probably get a pan big enough to hold all three bands and get a gallon of strong solvent such as MEK, Acetone, or Xylene and pour it over the bands and just let them sit until the linings fall off. Covering the pan to make it as air tight as possible would slow the evaporation of the solvent.
Posted: Sun Jun 30, 2024 12:52 pm
Did you do this while checking the bands or was it already that way?
Posted: Sun Jun 30, 2024 12:58 pm
by Moxie26
The picture shows what we saw when the inspection cover was first taken off
Posted: Sun Jun 30, 2024 1:36 pm
Good catch.
Obviously you need to address the non locking detent situation.
Posted: Sun Jun 30, 2024 1:47 pm
by Moxie26
Previous owner did not know about the locked position of band's adjustment
