I Just Replaced Front Spring Bolt…
Posted: Fri Jun 28, 2024 9:38 am
by George House
Howdy Forum Friends,…when I was laying under the axle greasing the APCO cap over the pitman ball I saw, to my chagrin, the absence of square nut below the main spring leaf 😳 I replaced the broken bolt with a substitute purchased from a prominent T parts supplier. With all the 7 or 8 spring leaf stresses on this 5/16” bolt,… why is it only Grade 5 ???
Re: I Just Replaced Front Spring Bolt…
Posted: Fri Jun 28, 2024 9:57 am
by jiminbartow
Regular bolts are grade 2. Grade 5 is a very strong bolt. The only stronger grade is grade 8. Grade 5 is more than strong enough for this application.
Posted: Fri Jun 28, 2024 10:14 am
by Norman Kling
Basically the bolt is used to keep the leaves centered in the frame and in relation to each other. The spring clip keeps it tight to the frame.
Posted: Fri Jun 28, 2024 8:23 pm
by Allan
Norm has nailed it. Once the spring is fitted in the frame the bolt does nothing but stop the leaves migrating. Any bolt will do that. The T bolts have a square head to match the square hole in the frame cross member, to make the location more positive.
