1910 Steering Column
Posted: Sun Jun 30, 2024 6:36 pm
I want to share how I finally rebuilt my 1910 steering column. I thought about this for over a year and finally came up with a solution that worked. I started by purchasing a two piece steering gear from a 1911. My 1910 steering gear was damaged beyond repair. I also purchased a new brass quadrant, but it wasn't the same as the original, so I filed the teeth on the original and used it.
I started by making a backing plate for the steering gear rivets. I had read that someone had tried to repair their column with the original solder, but was unsuccessful and only managed to discolor the brass. I took a different approach. After polishing all of the brass parts, I installed the brass control rods. I then mixed up some 4 hour epoxy and applied it to the inside of the two brass pieces and then tightly bolted them together.
The following day, I removed three bolts from the steering gear and installed the brass rivets, one at a time. While clamping the backing plate to the outside, I used a rivet gun on the inside which is never seen. I then repeated the same process for the remaining three rivets.
Next I assembled the brass quadrant on the steering column, carefully aligning the rivet holes. I used a caliper and measured the total distance required for the two rivets. Using the same caliper, I cut four rivets half of that distance with a little wiggle room. I then proceeded to epoxy these rivets into place. After I used the rivet gun tip and carefully seated the rivet heads into the angled brass quadrant.
See the pictures below:
