Please forgive my abysmal ignorance: Kingston L-4
Posted: Thu Jul 25, 2024 5:32 pm
I have assembled the cleaned L-4 brass body Kingston L-4 carburetor that I mentioned in last week's posting and have yet three questions. This is my first Kingston L-4 and the MTFCA carburetor booklet left a lot of unanswered questions.
(1) In various sources, the drain assembly is shown under the throttle intake (in front) and in others it is shown beneath the choke orifice (in back). I realize it will function in either orientation, but which is correct? Front or rear? Check out pictures in the MTFCA booklet, Bruce's "Bible", vendors' on-line photos and various issues of national club magazines. That drain valve is located all over the place! I had a a 50-50 chance of guessing correctly, as can be seen from the photos. 'Probably the other way, though, right?
(2) This is my first carb that doesn't have any jets! I have read the theory behind how this carb works with its air valve, but I am still a bit uncomfortable with this design. When the adjuster needle is turned down all the way until it bottoms out, is the hole at the bottom of the main body (see yellow arrow) supposed to be closed off? This one isn't. I can hear air blowing into the bowl even with the adjuster needle closed fully. Is this correct or should I be worried?
(3) As a follow-up to question #2, is this hole really left open like that? Nothing is missing? According to the exploded drawings of this carb, I can't find anything missing.
Thanks for your input. The carb goes back on the engine tomorrow.
Marshall[image][/image]
