Dome piston and RAJO head.
Posted: Thu Aug 29, 2024 2:14 pm
by Dan Hatch
Customer asked if he can run dome piston with or of the new Chaffin RAJO heads? I am not sure so I will ask here.
What about the original ones? Thanks Dan
Re: Dome piston and RAJO head.
Posted: Thu Aug 29, 2024 2:22 pm
by Jerry VanOoteghem
Dan Hatch wrote: ↑Thu Aug 29, 2024 2:14 pm
Why not ask Chaffin?
Posted: Thu Aug 29, 2024 3:45 pm
by Mark Chaffin
Yes. The new RAJO head utilizes 14mm plugs which are smaller in diameter than the original spark plugs. As such they were placed higher in the chamber to allow the use of domed pistons for higher compression.
Posted: Thu Aug 29, 2024 3:57 pm
by Dan Hatch
Thanks Mark. So that means original ones can not use dome pistons. Dan
Posted: Thu Aug 29, 2024 4:16 pm
by tman1913
High compression piston can be used in both new and old Rajo heads.
Posted: Thu Aug 29, 2024 4:25 pm
by Mark Chaffin
Mike is correct. The only factor to consider is how much has already been milled off the bottom.
Posted: Thu Aug 29, 2024 7:10 pm
by AndyClary
I have domed pistons with a Chaffin head and a C crank. Be prepared to run premium gas. I guessed at the piston dome value and came up with 7 1/2:1 compression. Again. There was some guesstimating involved. If I recall Mark was building a similar motor and may have better numbers.
The other factor is to keep an eye on valve lift, I have about .070 with a mild lift overhead cam.
Andy
Posted: Thu Aug 29, 2024 7:42 pm
by walber
Really only .070?
Posted: Thu Aug 29, 2024 7:49 pm
by AndyClary
Yeah Walt. The dome comes up pretty high and I believe the chamber is only 1 1/8” deep. The duration of the cam may have something to do with it but I didn’t get a cam card. I checked with no head gasket so it’s probably closer to .100. I think a 280 cam might skin by but probably not a 300. Runs good.
Andy
Posted: Thu Aug 29, 2024 8:05 pm
by speedytinc
AndyClary wrote: ↑Thu Aug 29, 2024 7:49 pm
Andy
The piston is not up to hit he valves when the valves are open unless you are over revving & floating the valves.
So, cam lift with rocker ratio isnt a factor either.
Posted: Thu Aug 29, 2024 9:40 pm
by AndyClary
Your probably right John, but I have always checked valve clearance. Funny, it’s never an issue on flatheads.
Andy
Posted: Fri Aug 30, 2024 12:16 pm
by elliott1936
One caution that I would say is don't go too high with the dome. A friend and was rebuilding his BB Rajo with domed pistion and we had a bad spark knock. This was 20 years age, maybe the gasoline has changed a bit. Tom
Posted: Fri Aug 30, 2024 1:31 pm
by speedytinc
Combustion chamber size varies so much from milling for higher compression over these heads lifes and depending on models from commercial to racing heads.
I see where the claim of 1 1/8" has been made. I have a head that looks like no or minimal milling @ 1" I thought that was the normal size.
I have a head that was severely cut to 3/4" chambers.
I do have one running BBR running an A crank & 292 pistons. The combustion displacement appears to be close to a stock T piston.
The horsepower is incredible as is. I dont see a need for more compression. But always open to improvements.
This thread has got me thinking to do a compression test.
Are these hi dome pistons stock T type, with stock rods & crank?
Couldnt be running a T crank or even stock journals on a scat crank ?
Posted: Sat Aug 31, 2024 9:47 am
by AndyClary
The Chaffin head has the 1 1/8 chamber, original heads are all over the board. If I had it to do over I probably wouldn’t have used the high compression pistons, but what the heck.
Andy
Posted: Tue Sep 03, 2024 9:59 pm
by speedytinc
AndyClary wrote: ↑Thu Aug 29, 2024 7:10 pm
Andy
I did a compression test on my BBR. I got 110# = 7.5:1 aprox. Thats with 292 pistons over an A crank.
You say run premium fuel?
Posted: Tue Sep 03, 2024 10:22 pm
by AndyClary
I got a little rattle on mine with regular. I need to check my total advance, I might be pulling the lever too much. I haven’t driven it enough to find where it likes to be.
Andy
Posted: Wed Sep 04, 2024 12:21 am
by Dan McEachern
Yea John, but the chamber depth on a real BBR is well under 1" deep..........
