Today’s project
Posted: Thu Jun 13, 2019 3:04 pm
by D.Yoder
Re: Today’s project
Posted: Thu Jun 13, 2019 10:15 pm
by Randall strickland
I like your depth gauge! I have a couple I need to do
Re: Today’s project
Posted: Thu Jun 13, 2019 10:39 pm
by Dennis_Brown
I am trying to figure out what you are repairing.
Re: Today’s project
Posted: Thu Jun 13, 2019 11:31 pm
by D.Yoder
Wish bone ball socket.
Ball socket
Ball socket
Re: Today’s project
Posted: Fri Jun 14, 2019 8:26 am
by Adam
Turn the speed way down. Maybe 200 rpm. Then it will look like this:
Re: Today’s project
Posted: Fri Jun 14, 2019 8:41 am
by Mark Nunn
Can you explain how you built up the material around the socket? Weld, braze, other method? I need to find a way to fix this.
Re: Today’s project
Posted: Fri Jun 14, 2019 9:00 pm
by D.Yoder
I use a wire welder.
Re: Today’s project
Posted: Fri Jun 14, 2019 9:09 pm
by 25 roadster john
Hello all,
My question is what do you use to form the socket?
Is this something that can be done in a drill press? :shock:
Re: Today’s project
Posted: Sat Jun 15, 2019 12:20 am
by BobShirleyAtlantaTx
I’m with John, please post a picture of your cutter, the model number and where to purchase. Thanks
Re: Today’s project
Posted: Sat Jun 15, 2019 7:32 am
by Dan Hatch
Tool is called ball end mill.
Re: Today’s project
Posted: Sat Jun 15, 2019 12:44 pm
by D.Yoder
Re: Today’s project
Posted: Sat Jun 15, 2019 1:16 pm
by RGould1910
An 1 1/4 " ball mill requires a lot of pressure to cut weld. I can't see how a drill press would work. I did the same thing using a tig welder and silicon carbide with a 1910 pan and the pressure warped the pan on a mill. I like the idea of brazing the hole. Not so tough to cut
Re: Today’s project
Posted: Sat Jun 15, 2019 8:21 pm
by D.Yoder
Richard, You need to drill a 3/8 inch pilot hole before you use the end mill. Doesn’t require as much pressure.
