Innertube backorder
Posted: Thu Sep 19, 2024 9:51 am
by Scott Rosenthal
Very common 30 x 3.5 brass stem innertubes must be extremely difficult to manufacture (Not)? Done two early I projects in the last two years when this same common wear item could not be readily sourced.
So allegedly these shipped items cannot be pinpointed with a tracking number (as vendor claims)? If tracking is not possible or not practical (unlikely), then much appreciation if qualified someone would explain this.
An industrial approach would be to produce a list of common Model T spares (like these), and to then determine quantities of those items that are required to be inventoried by vendors as critical spares.
Scott
Re: Innertube backorder
Posted: Thu Sep 19, 2024 9:58 am
by babychadwick
We just ordered 4 with no problem from langs
Posted: Thu Sep 19, 2024 10:29 am
by Scott Rosenthal
Hi Chad;
No these are not available from any current vendor. Got 2 of these you would be willing to sell?
Scott
Posted: Thu Sep 19, 2024 10:32 am
by Scott Rosenthal
Should clarify...ordering these is not the problem...laying my hands on the parts is the issue
Posted: Thu Sep 19, 2024 11:58 am
Are you talking about tracking the tubes to the supplier from the manufacture or from the supplier to you? Any supplier worth their salt will be sending you a tracking number when they ship to you and once you have that tracking number all you have to do is cut/paste or type it into your search box, then maybe pick the carrier they were sent by.
Or you could make your own brass stemmed tubes.
http://www.sheepisland.com/cars/tech/metal_stems/
Posted: Thu Sep 19, 2024 1:58 pm
The tubes being offered today are not what they should be. I only use rubber stem tubes for my cars, because the brass stems they use today are not correct. I have to put the correct stems on my tubes, because the vendors can't do their job correctly!
Posted: Thu Sep 19, 2024 2:30 pm
by RecklessKelly
Try Lucas Tire.
Posted: Thu Sep 19, 2024 3:00 pm
Mister Thrifty is too cheap to pay the extra money for metal stem tubes. I buy tubes with rubber stems, remove the stems, and install my own metal stems. Original metal stems can often be found at swap meets for $2 or $3. I use the "wrong" size because all the repop covers will fit them. All current metal stem tubes come in the larger size, which is incorrect for a Model T. If you're in the market for originality you can use the correct size stems. If you care more for convenience, either size will do.
https://dauntlessgeezer.com/DG110.html
Posted: Thu Sep 19, 2024 7:00 pm
Are you talking about quality Blockley tubes? If these are in short supply, there is an excellent Michelin alternative.
Posted: Thu Sep 19, 2024 9:31 pm
by Craig Leach
Didn't know these are hard to find? While looking for ( actually I was digging through boxes trying to remember where the heck I stashed all my
21" tubes ) I found 2 that I forgot I had. One Universal brass stem & one real heavy rubber stem marked made in EEC? They have been stored in
the A-C for all of the time I have had them & they show no signs of deterioration at the folds. I'm sure I can be persuaded to part with them.
I also have some liners.
Craig.
Posted: Fri Sep 20, 2024 7:31 am
by Scott Rosenthal
Thanks for this feedback gentlemen. The tubes sought are the current early brass stem style vs rubber. Was not aware that the current stems are not OEM correct?..I'm 4 restored cars into hearing this....but truly not surprised. Also aware that there are at least 2 different brass stem styles out there.
I have an order in place for these but the vendor has not received them from this supplier, hence my question about where they are in the pipeline to that supplier. I agree this information is the vendor's business, however they missed their published receipt date, impacting mine and multiple other end user's schedules.
I appreciate the offer Craig thank you, but need a brass stem set. These are for a friend's 16 that I'm helping out with.
Having had availability issues with these same ā“parts before, I should have gotten ahead of this earlier. As Steve says, these tubes can be home built from parts, which is what I'll likely do if these remain delayed.
Posted: Sat Sep 21, 2024 4:17 am
Scott, the tubes available do have correct OEM sized stems for a variety of cars, and there is a lot of hardware available to fit them. It is just that some purists would rather have the smaller diameter stems used by Ford.
The stem size does not bother me, even rubber ones, as Dill dust covers which screw onto the small valve cap thread will fit all stems, and they can be adjusted for length. Each to his own.
