Casting numbers on head
Posted: Wed Sep 25, 2024 11:18 am
by Franko
Do these numbers on my 1914 engine head indicate that it’s a 1926 head?
Re: Casting numbers on head
Posted: Wed Sep 25, 2024 11:32 am
by Russ_Furstnow
Those numbers are the month and the day the head was cast (May 26th).They are close to the date the block was cast (May 4th). . I hope this helps, Russ Furstnow
Posted: Wed Sep 25, 2024 11:34 am
If you have a later high head you compare it with the head on your 14 and see if it’s the same height. That’s the easiest way to tell. Others that know if the casting number is for the later heads may can tell you the number information.
Posted: Wed Sep 25, 2024 1:17 pm
The water inlet appears to be a modified ? Model A part.
Posted: Wed Sep 25, 2024 2:31 pm
by JTT3
Measure from the bottom edge of the head to the top of a head bolt hole boss of the first hole on the right side. Should be a hair under 2 inches if it hasn’t been milled if it’s a low head.
Posted: Wed Sep 25, 2024 5:17 pm
by Franko
Thank you everyone ! !
Posted: Wed Sep 25, 2024 6:13 pm
by Chris Haynes
That is not the original engine number. You can see how low the number area is compared to the rest of the water inlet surface. The original number has been milled off and that number stamped in its place. Although this is common practice it is illegal.
Posted: Wed Sep 25, 2024 6:57 pm
by Wayne Sheldon
That used to be legal to do, hence was commonly done. Exact rules varied by state.
Posted: Wed Sep 25, 2024 7:07 pm
by Wayne Sheldon
Earlier low head styles of model T heads often had casting dates on them, but only the month and date, no year given. Several other details on the head may or may not help narrow down the year.
I don't even know if any high heads have a casting date at all? But I am fairly sure that most do not.
Posted: Wed Sep 25, 2024 7:50 pm
by Kerry
Some seem to have year as well.
Posted: Thu Sep 26, 2024 9:04 am
by TWrenn
Wow Kerry....would love to have THAT!!
