bolt source for fly wheel start ring
Posted: Mon Sep 30, 2024 9:28 am
by johnr
I am setting up an engine to be run without a magneto. any idea where i can obtain 1/4 x 24 bolts to attach the starter ring ?
Re: bolt source for fly wheel start ring
Posted: Mon Sep 30, 2024 10:04 am
by Dan Hatch
For my money Dan M on here has the best slinger and bolt kit.
He also makes a ring to keep triple gear pins from backing out.
I will not remove magnets for customer without one of those kits.
Posted: Mon Sep 30, 2024 12:20 pm
by johnr
Thank you for the reply. I already have the retaining ring and slingers made. looking for a source for the bolts to attach the starter ring.
Posted: Mon Sep 30, 2024 12:21 pm
by big2bird
Try Mc Master Carr.
Posted: Mon Sep 30, 2024 12:34 pm
by speedytinc
6mm hex head.
I have done many conversions using metric bolts.
Posted: Mon Sep 30, 2024 1:24 pm
by Craig Leach
Hi John,
The 6mm will self lock in the threads so make sure the length is correct to tighten the ring gear.
Posted: Mon Sep 30, 2024 1:33 pm
by speedytinc
I Get the length to stick out 1/6" additional & peen the ends.
I use lock washers also. That & the self locking nature of the close thread makes for a triple safe install.
Never had one come loose.
P.S. These bolts are for the original 14-24 thread. I have no experience with the current incorrectly threaded 1/4-24 ring gears.
Posted: Mon Sep 30, 2024 1:41 pm
by Dan McEachern
You can also retap the ring gear 1/4-28 and it will work just fine. As John mentioned you can also tap to a 6mm thread. Not sure I would just force the 6mm thread in to the ring gear.
Posted: Mon Sep 30, 2024 3:06 pm
by ModelTWoods
Is this an item the vendors do NOT stock?
