rear axle end play
Posted: Tue Oct 22, 2024 4:47 pm
by johnr
can someone give me dimensions or measurements for maximum movement that is acceptable for rear axle before rebuild.
Thank you.
Re: rear axle end play
Posted: Tue Oct 22, 2024 4:56 pm
by speedytinc
Axles & carrier must freely rotate. .005" is perfect. .010" is acceptable.
Posted: Tue Oct 22, 2024 10:34 pm
by Craig Leach
Thrust washers are about 1/4” thick if close to that it’s time to open it up. Ring gear to pinion clearance is.010 +/- .002 so if you have .025 or more then it’s worth a look. Best is to check these when a rebuild is done and write it down for reference in the future.
