Instructions for Midget Glo-Lite
Posted: Sat Nov 02, 2024 10:26 pm
by WorldChamp1914
I have a NOS Midget Glo-Lite but no instructions……does anyone have the original instructions or maybe photos, did it come with a switch?……Thanks Guys!
Re: Instructions for Midget Glo-Lite
Posted: Sun Nov 03, 2024 1:41 am
This link has some similar & had this ad https://www.mtfca.com/discus/messages/1 ... 28288.html
Posted: Sun Nov 03, 2024 3:09 pm
I'd guess it had no switch. You could connect it to either of the headlight terminals on the firewall terminal strip so that it would come on when either the high or low beams were turned on, or to the tail light wire, so that it would come on whenever the lights were switched on. Earlier cars with magneto lights would require a different approach, I'd think.
Posted: Sun Nov 03, 2024 4:33 pm
Since its an indicator if the "headlights lights are on" then wire to the taillight post on the terminal block. That way it would be turned on when the switch was in the DIM or ON position for headlights. If just "Headlight" as in "not DIM" then to the #6 position (says Bright in the diagram) on the terminal block.
Posted: Sun Nov 03, 2024 10:48 pm
by WorldChamp1914
Thank you very much!
Posted: Mon Nov 04, 2024 5:45 pm
by ModelT46
MOTO-LITE was another brand of the same device. I have a NOS one in the original box Here are two photos.
Posted: Mon Nov 04, 2024 10:07 pm
by WorldChamp1914
Wow…..thanks
Posted: Mon Nov 04, 2024 10:09 pm
by WorldChamp1914
How can I replicate the cord part?…….Do you have any closeups of the metal sheath?
Posted: Mon Nov 04, 2024 10:11 pm
by WorldChamp1914
How long is it?…..Were there any installation instructions?
Posted: Mon Nov 04, 2024 11:14 pm
by WorldChamp1914
I see it now, 5 feet long. What does the end look like?…..Thank you very much!
Posted: Tue Nov 05, 2024 4:03 pm
by ModelT46
a steel braided cable. a fitting to fil the moto lite. No fiting on the other end. I once h ad about 10 of these. None hade any instructions. I assume then you woukld need to install an fiting on the end that goes to you lighting system.
Posted: Tue Nov 05, 2024 5:03 pm
by WorldChamp1914
