Carburetor gas storage tank
Posted: Sat Nov 23, 2024 7:57 pm
by Tmooreheadf
Some years ago, I saw a small tank that was mounted in the frame rail adjacent to the carburetor that stored a small amount of gas to be used in low tank levels so as not to let the carb run out of gas on a hill. Anyone recognize my pitiful description? Also, I’ve seen small, homemade tanks made out of short lengths of copper pipe, with fittings, to store small amounts of reserve gas to supply the carburetor? Any photos would be appreciated or ideas of such? While friends have shared where they pressurize the gas tank with exhaust gas with great success, I’m a scardy cat for using that idea! And not inclined to use a fuel pump or vacuum pump system! Simple is good!
Tom
Re: Carburetor gas storage tank
Posted: Sat Nov 23, 2024 8:04 pm
by Dan Hatch
Get one of Scott’s float valves and you will be surprised how low you can go.
Posted: Sat Nov 23, 2024 8:44 pm
by Tmooreheadf
I’m using them now and they work well. I’ve been in a couple situations lately where unless the tank had been in the cowl, myself and a couple others, even with 7 gals, did not make it. Scott’s has eliminated all other situations but these couple. Adding a gallon finished the job.
Posted: Sat Nov 23, 2024 8:46 pm
by TeveS-Nor Cal
Scott who?
Posted: Sat Nov 23, 2024 9:03 pm
by Moxie26
Just make sure the vent hole in the gas cap is clear, and you won't have any problems
Posted: Sat Nov 23, 2024 11:56 pm
by RVA23T
Scott who?
Scott Conger here is the link in the parts for sale. I also suggest getting a set, cost less than a Stromberg OF!
www.mtfca.com/phpBB3/viewtopic.php?f=5& ... =full+flow
Posted: Sun Nov 24, 2024 10:28 am
Here is an accessory gas tank for the Ford, one of Jay's contributions. Could be duplicated with some creative parts and a small gas tank.
http://www.mtfca.com/discus/messages/118802/140733.html
Posted: Sun Nov 24, 2024 10:37 am
by AndyClary
Not seeing the hill, I’d think that if seven gallons isn’t enough you have another problem.
Andy
Posted: Sun Nov 24, 2024 10:49 am
Andy
Thought that too when reading, could well be the sediment bowl screen is partial clogged. Happened to me, could not run up a pretty steep hill on tour in VA with my FL flat land touring ;) Ran fine on level or some hills.
Came to find out the screen was partial clogged (photo is another screen) with fine fibers :? Believe the gas cap hole sucked in those fibers from the coarse burlap used to cover the spring set under the front seat upholstery. Over time that burlap gave off fibers, as could see them on the top of the tank too.
Soldered on new screen and cleaned the bowl, full gas flow then.
Posted: Sun Nov 24, 2024 11:11 am
by Tmooreheadf
His larger needle and seat work very well. I am very pleased with the two I have.
Posted: Sun Nov 24, 2024 11:43 am
by 1923Touring
Tom, one of your club members has exactly what you are describing, though I don't remember who it is off hand.
Posted: Sun Nov 24, 2024 11:50 am
by perry kete
If you're looking for a small gas tank, I think one from an older push lawnmower would work. They hold a couple of gallons and would be easy to connect. I may have one in my shop somewhere if you're interested, I can go look for it.
Posted: Sun Nov 24, 2024 1:00 pm
An auxiliary gas tank, for the most part, is a patch for restricted fuel flow. Note the Long Beach hill climb. All the cars made it over that very steep hill. How many T's, today, run/need such an extra tank? (Not including the "improved " car cowl tank. They have a great advantage)
Climbing a hill requires highest gas demand especially if reving the motor in low pedal to keep a low horsepower T moving. An extra fuel filter, a partially clogged screen, a crimped line, low fuel tank or a carb needle & seat made with too small an inlet will restrict the maximum fuel volume needed to keep running. Scott C's modified hi volume needle/seat solves that one problem of an incorrectly sized seat in the viaton units.
Posted: Sun Nov 24, 2024 2:04 pm
Posted: Sun Nov 24, 2024 2:35 pm
by RecklessKelly
If you disconnect the fuel line and run the gas into a container, you should have a steady flow. If not, remove the gas cap and check the difference. If still bad, look at the shutoff valve and the gas line.
Posted: Sun Nov 24, 2024 8:38 pm
by Tmooreheadf
On level ground with five gallons in the tank, with the line disconnected from the carb inlet, and the open line held at the same level of the carb inlet, it flows a stream about 4” out. I’d think that is plenty of flow. I may be wrong!
I’m sincerely appreciating all of the good comments and suggestions.
Posted: Mon Nov 25, 2024 8:39 am
by RecklessKelly
That should be fine. If you wanted to add some fuel head pressure, wind some annealed seamless copper tubing around a pvc tube. I added a loop on an outboard to prevent stalls when I gassed it out of a wake. It worked. Mount it just above the carb away from the exhaust. I wouldnt add a separate tank that has an opening, keep leak points and fume escape to a mininum.
