Smoking Ammeter? Any ideas?
Posted: Sun Dec 01, 2024 4:39 pm
by Fozz71
Hey fellers, drove my car around today and all was well. Battery was charging and no issues. Came home and tightened up my 4 bolts holding my switch and ammeter and hooked up my battery and saw a little smoke starting to come from my ammeter- it was hot?
Here is my wiring- anything look out of place? A little puzzling to me.
Thanks,
Jim
Re: Smoking Ammeter? Any ideas?
Posted: Sun Dec 01, 2024 5:12 pm
by Moxie26
https://youtu.be/n85WuQachEQ?si=vkoYmr_DkAmpn6hQ . ....... Same problem with model a reproduction ammeters... Just follow the instructions and Make the connections better.
by TRDxB2
If the tag says GEN then possibly Looks like you have a wire tagged GEN to the MAG screw position. This by itself would just effect the switch position BUT likely other wires arr crossed.
There are two screws for the BAT position with a jumper across them so it doesn't matter which is used for that connection
Another possibility if all wiring is correct, over tightening the nuts on the ammeter could brake loose the internal connections
Same wiring rectangle or oval plate
Posted: Sun Dec 01, 2024 5:17 pm
by Moxie26
Till you're ready to fix your problem, I would suggest disconnecting the positive terminal on your battery just for safety's sake
Posted: Sun Dec 01, 2024 5:31 pm
by mtntee20
Moxie26 wrote: āSun Dec 01, 2024 5:17 pm
ONLY if it is a POSITIVE ground. ALWAYS DISCONNECT THE GROUND AT THE BATTERY. The GROUND can be Positive OR Negative. Look to see which cable goes to the frame. That's the ground.
Removing the ground is safer because IF your tool (wrench or whatever you are using) happens to touch part of the frame, there will be no sparks and no damage.
Posted: Sun Dec 01, 2024 5:49 pm
by Fozz71
Yep, the negative is disconnected at battery.
Posted: Sun Dec 01, 2024 6:00 pm
by Moxie26
The same happens if the positive terminal is disconnected from the battery ........ Would also help if you installed a 20 amp fuse at the starter switch terminal that the yellow #12 gauge wire connects.
Posted: Sun Dec 01, 2024 8:19 pm
by 600wt
A similar smoking situation happen to me on a tour a couple of years ago. Lots of smoke! It turned out that a "hot wire" had been rubbing on the bottom edge of the dash for years and the sharp edge of the dash rubbed the insulation off of the wire, creating a short. There was a fuse on the line but the fuse never blew. The problem was not hard to find.
Posted: Sun Dec 01, 2024 8:26 pm
by TRDxB2
Fozz71 wrote: āSun Dec 01, 2024 4:39 pm
Thanks,
Jim
I forgot to ask. Why are there 3 wires connected to the ammeter. The Green is okay, one should be to the battery on the opposite post, so what the other one on the post with the green wire?
Posted: Mon Dec 02, 2024 8:22 am
by Fozz71
That's what I was thinking, I'll have to check that 3rd wire out.
Posted: Mon Dec 02, 2024 10:18 am
by TRDxB2
Fozz71 wrote: āMon Dec 02, 2024 8:22 am
Here is a wiring diagram for cars with starters & generators. I also updated the other diagram to show where the Generator connection goes. Its also possible to connect it at the ammeter to where the yellow/black (your green) wire is. Check all the connections & what you noted in the tabs
Posted: Mon Dec 02, 2024 11:22 am
by TMiller6
I suspect that if you remove all wires except the green one from your ammeter, you will still see smoke.
Iām thinking the paper insulator inside the can is bad.
Posted: Mon Dec 02, 2024 1:11 pm
by Moxie26
Yeah, hello comfortable, the paper so-called insulator is getting warm because of the loose connections inside the ammeter. If you follow that video that I posted, those loose connections can be corrected, at least tried to be corrected. If not, you'll have to get a better 20-0- 20 amp meter.,.......... Could it be that a previous owner put that green third wire on the ammeter as a source of power for auxiliary lighting or even a cigarette lighter, or even a charge port for some electronic equipment such as a Garmin or a cell phone?...... Where does the other end of that green wire end up?
Posted: Mon Dec 02, 2024 1:33 pm
by Fozz71
Posted: Mon Dec 02, 2024 1:51 pm
by RajoRacer
That's the same repro you have now !
Posted: Mon Dec 02, 2024 2:59 pm
by Moxie26
Fozz71..... If you do get it, just use the video as a guide and with an analog meter, my choice, check the readings, you may have to proceed to solder the connections.
Posted: Tue Dec 03, 2024 8:18 am
by Fozz71
Thanks for all the help, I moved the extra wire from the ammeter back to the screw on the switch (where it seemed to be missing) and everything is good now. Yes, the new ammeters are kinda junky but I tightened all connections and will keep an eye on it. Thanks for all the help!
Posted: Tue Dec 03, 2024 10:07 am
by J1MGolden
Use a different ammeter with an ammeter adapter.
This is one I did for a 12 Volt Alternator.
This is the tool.
