Rear axle inside bearing location
Posted: Fri Dec 20, 2024 8:49 am
by Rajo T Speedster
Just setting up my pinion gear on a shortened drive shaft for an auxilliary gearbox installation.
What stops the rear axle inside bearing from sliding back and forth. On the left side of my car the bearing can move up to 1". On the other side it is located by the end of the carrier.
In the gasket kit for the rear end there is a small ( one inch) red fibre washer. Where does this go?
Re: Rear axle inside bearing location
Posted: Fri Dec 20, 2024 8:58 am
by Mark Nunn
The red washer goes between the ends of the axles in the carrier. It keeps the shafts from moving in and out.
Posted: Fri Dec 20, 2024 10:11 am
by Jerry VanOoteghem
Rajo T Speedster wrote: ↑Fri Dec 20, 2024 8:49 am
Something seems to be seriously wrong. The red washer goes between the inner ends of the two axle shafts. It will do nothing to take away 1" (!) of side-to-side bearing travel. If you don't have the MTFCA rear axle rebuild manual you should seriously consider buying one.
Posted: Fri Dec 20, 2024 10:43 am
by Mike Silbert
As a beginning point look at the assembly drawings in the technical section, Vowell Art
app.php/gallery/album/44
More drawings are available on his personal facebook pages
The MTFCA sells a series of repair manuals on how to fix your car.
These are the best bargain of information for the cost and a must for everyone doing repairs.
But your best bet is to find someone with experience nearby but.
I see you in Western Australia so this may not be possible.
Rebuilding the rear axle assembly is a step by step procedure that needs to be followed to be successful.
1" of end play is a major problem probably caused by parts not in the correct locations.
Maybe it could be figured out by pictures, but this will be the hard way to go.
Nothing will beat experience or good i instructions.
Mike
Posted: Fri Dec 20, 2024 10:56 am
by TRDxB2
Do you have all the parts?
Part 2506 is normally red but different thickness may be required - gray or brass
Better check your axle to see if the retainers & key are in place
Posted: Fri Dec 20, 2024 11:40 am
by speedytinc
Both ends of the axle housing have an internal thick ring held in with the rivets that hold the backing plate or pumpkin onto the tube.
This is your bearing stop. Its right @ the edge of the sleeve. 1" is really excessive, even for a lot of wear from a rubbing bearing cage.
The only way I can think you could have an extra 1" possible bearing travel would be if the collar was never installed or removed in a "re-tube" process on an old pumpkin. Possibly a shorter than normal bearing??
Posted: Fri Dec 20, 2024 5:54 pm
by Norman Kling
If the axle shaft moves it could be an old babbit ring inside. The replacement bronze rings last much better. The right side movement would be limited by the gears.
Posted: Sat Dec 21, 2024 9:54 am
Norman Kling wrote: ↑Fri Dec 20, 2024 5:54 pm
He states it's the inner bearing that moves an inch. I'm wondering if he's using the correct bearing. Are they both the same length? Some pictures would definitely make it easier to help him.
Posted: Sat Dec 21, 2024 10:38 am
by Norman Kling
Should be the same length. The sleeves will be different depending on the right or left. The dimple on the sleeve will fit into a hole in the tube with the open side of the sleeve down.
Posted: Sat Dec 21, 2024 11:24 am
by Kevin Pharis
As I recall, the pinion bearing is the same ID and OD as the rear axle bearings, except that it is roughly 1” shorter in length. All 4 roller bearings in the rear axle are the same length, and are equal in length to their outer race. As stated above, there are heavy rivet backing rings that act as inboard stops for the bearings. I suspect that you have an extra pinion bearing…
1” diameter fiber washer goes between the axle ends when assembling the spider gears and center carrier
Posted: Sat Dec 21, 2024 11:57 am
by speedytinc
Kevin Pharis wrote: ↑Sat Dec 21, 2024 11:24 am
Rollers on the driveshaft bearing are larger. (.562") & the overall OD much larger also. So, even being shorter, it wouldnt fit.
Hyatt bearings came in many different sizes, but it would be obvious if one of the 4 were an inch shorter.
So, the mystery continues.
Posted: Sat Dec 21, 2024 12:32 pm
by Kevin Pharis
That’s what I get for converting my cars to tapered roller bearing spools…
Thanks for the pinion bearing details
Posted: Sat Dec 21, 2024 1:08 pm
speedytinc wrote: ↑Sat Dec 21, 2024 11:57 am
Perhaps not obvious to the OP
But, since we have heard nothing back, we may never know.
Posted: Sat Dec 21, 2024 1:39 pm
by Mark Gregush
Jerry VanOoteghem wrote: ↑Sat Dec 21, 2024 1:08 pm
It's only been a day, don't forget the date/time difference.
Posted: Sat Dec 21, 2024 2:27 pm
Mark Gregush wrote: ↑Sat Dec 21, 2024 1:39 pm
Wow, you're right. Thanks!
Posted: Sun Dec 22, 2024 2:14 am
by Rajo T Speedster
When the left side axle tube was sitting upright in the vice I installed the bearing into the tube. The top the bearing went down about half an inch below the thrust washers level.
Tried to install the axle and it wouldn't go in very far. I then installed the bearing onto the axle shaft and held it there while I inserted the axle shaft into the tube. All went OK. There must be some sort of ledge in the tube that hold the bearing in position when the axle is in position.
All parts shown in the exploded view are in my setup.
Problem resolved.
Thanks for all the advice given.
I am now just about passing Ford T 102.
John
Posted: Sun Dec 22, 2024 12:10 pm
by speedytinc
"Tried to install the axle and it wouldn't go in very far. I then installed the bearing onto the axle shaft and held it there while I inserted the axle shaft into the tube. All went OK. There must be some sort of ledge in the tube that hold the bearing in position when the axle is in position."
The bearing surfaces are smaller than the raw axle shaft between. When installing the assembly into a housing, the inner bearing has to be in place next to the differential case first. Sounds like the lesson you learned. That procedure is noted in par. 616 of the T1 service manual.
Posted: Sat Dec 28, 2024 8:34 pm
by Shrshot
I have a question about rear axle outer bearings/sleeves. How much up/down or side to side movement should there be between the axle and the outer bearing?
Posted: Sat Dec 28, 2024 10:59 pm
by DHort
Kent
I would say to you, essentially zero.
Posted: Sun Dec 29, 2024 7:21 am
by Allan
Kent, I would say a bit more than zero, perhaps bugger all! Most good used Hyatt bearings have .002" t0 .003" wear, add a bit for wear in the sleeve and there you have it. The better lubed bearings in the diff centre are usually less worn than the outer ones which carry the load of the car.
Posted: Sun Dec 29, 2024 9:37 am
by Shrshot
Thanks for the info, it's kind of what I was thinking. I started to pull the rear axle last night and going to rebuild it. It has had a leak at the left wheel and where the pinion spool bolts to the axle housing. I know the disk/axle shafts must have some wear as there's some end play between the shafts. It still has the original outer bearings as they have the grease grooves in them. The cages are tight, but the rollers themselves are awful loose. I'll keep you all informed when I get it apart. The car is a 1926, but definitely not original.
Motor/trans/rear axle are a 1924. Thanks again, Kent
Posted: Sun Dec 29, 2024 12:24 pm
by TRDxB2
some specs ......................
