ball cap orientation
Posted: Fri Jan 03, 2025 12:11 pm
by johnr
There is a thru hole on babbit portion of the ball cap .
Does orientation Matter ?
Thank you
Re: ball cap orientation
Posted: Fri Jan 03, 2025 12:16 pm
by big2bird
Face up to catch oil.
Posted: Fri Jan 03, 2025 12:19 pm
by speedytinc
Hole to top.
However........ If you have a transmission trash screen, it dumps A LOT of extra oil right on the 4th main leaking excessive oil into the U-joint, especially if the 4th main is on the loose side of the clearance spec.
