Sediment Bowl Lead Gasket
Posted: Tue Jan 14, 2025 4:16 pm
by suley
Hello all,
The lead gasket of the sediment bowl is out of stock everywhere for some time now. Is there an alternative to it which I can use?
TIA
Re: Sediment Bowl Lead Gasket
Posted: Tue Jan 14, 2025 4:33 pm
by TXGOAT2
You might cut one from a sheet of thin lead that is made for roof flashings.
Posted: Tue Jan 14, 2025 5:43 pm
by Allan
Excellent advice Pat. I use a box knife for this. Be sure to make the hole first, Rough cut the OD larger than needed, fit the washer and outlet, then trim the OD in place. Otherwise it is very hard to stop things stretching to make a loose fit in the pumpkin body.
Allan from down under
Posted: Wed Jan 15, 2025 1:34 am
by suley
Another big THANK YOU!
Posted: Wed Jan 15, 2025 8:25 am
by Shannon_in_Texas
McMaster-Carr has lead sheets of various thickness available as well:
https://www.mcmaster.com/products/lead/lead~/
Posted: Wed Jan 15, 2025 12:10 pm
by Craig Leach
In a pinch you can take Teflon tape ( a lot of it ) fold it over several times then spin it into a cord, Wrap it around many times, hold the ends
and tighten it up. Maybe we should start practicing soldering solder to make sealing rings?
Posted: Sat Jan 18, 2025 6:58 pm
by John kuehn
This might a good alternative for a lead gasket for the sediment bulb. I didn’t know solid lead wire is sold as fishing line! Amazon has it in a roll of 3/16”. Wrap it around the screw n connection, overlap a little. Tighten it up and cut off the overhang.
Posted: Sat Jan 18, 2025 8:12 pm
by Allan
John, I think that lead is used to add weight around lines without altering whatever bottom in in use. The same stuff can be used to wrap around the spokes when balancing wire wheels.
Posted: Sun Jan 19, 2025 3:14 pm
by TRDxB2
who's to know its not "authentic"
