Wrong U-Joint
Posted: Fri Feb 07, 2025 3:34 pm
by mortier
I just got a U-Joint off eBay for my '15 T (the one in primer), but looks like I made a mistake. What is this one off of?
Re: Wrong U-Joint
Posted: Fri Feb 07, 2025 4:27 pm
by Kerry
Accessory transmission uni.
Re: Wrong U-Joint
Posted: Fri Feb 07, 2025 4:32 pm
by speedytinc
Are you guessing or do you "know"??
Which accessory transmission?
Re: Wrong U-Joint
Posted: Fri Feb 07, 2025 5:26 pm
by George House
I had one like that for a Muncie Accy T transmission…..
Or was it 2 ‘female’ shafts ?
Re: Wrong U-Joint
Posted: Fri Feb 07, 2025 5:37 pm
by speedytinc
Muncie uses a special short female end that is also a bearing race. Female square into trans.
I have seen shortened, stock U-joints that apparently work with no bearing support surface.
I have a NOS, Ford script, U-joint as OP shows. Looks factory assembled. Mistake??
I thought it might be for a PTO on a Fordson, since there are a few out there, but have not seen conclusive evidence.
Re: Wrong U-Joint
Posted: Fri Feb 07, 2025 7:01 pm
by Jerry VanOoteghem
The rivets on the one in primer are not done by the factory. See how crude the peening is? It appears that someone made this version for some special purpose. Maybe to drive a PTO pulley???
Re: Wrong U-Joint
Posted: Fri Feb 07, 2025 8:11 pm
by speedytinc
Mine looks to be factory riveted once.
I get your point. & the 2 rivets seen are in 2 different directions on OP's.
