Top Boot Straps
Posted: Fri Feb 14, 2025 12:38 pm
What is the proper name for the metal tips that are crimped onto the 5/8" woven cotton top boot straps? I can't find any, because I don't know what they are called.
Re: Top Boot Straps
Posted: Sat Feb 15, 2025 8:25 pm
by Erik Johnson
Too bad RV Anderson isn't around as he could tell you the proper trade name of the end caps.
However, boning end caps are used in corset making and are readily available in 1/2" which may suffice.
For example:
https://www.amazon.com/caps-Spiral-Stee ... 4NSPH?th=1
If you Google boning caps or boning end caps, you can find variations on the steel end caps.
Re: Top Boot Straps
Posted: Sat Feb 15, 2025 8:48 pm
Re: Top Boot Straps
Posted: Sat Feb 15, 2025 10:17 pm
by Erik Johnson
He's looking for 5/8" C tips like the one shown in the photo below of the original top boot from my father's 1917 touring.
Re: Top Boot Straps
Posted: Sun Feb 16, 2025 8:27 am
by CudaMan
I did a Google search for "metal belt tips" and came up with a bunch of modern equivalents.
https://www.google.com/search?q=metal+b ... e&ie=UTF-8
Re: Top Boot Straps
Posted: Sun Feb 16, 2025 11:48 am
If you search for webbing "c" tips you'll find the exact thing,
except nobody seems to make them for 5/8" wide webbing any longer. McMaster Carr even carries them, but not for 5/8". Maybe the 1" wide variety can be scrunched down for 5/8"???
Re: Top Boot Straps
Posted: Sun Feb 16, 2025 12:06 pm
by Erik Johnson
As I posted earlier, 1/2" C Tips are readily available from a number of vendors under the moniker of boning caps and are marketed to corset makers. Click on the link in my first post.
In my opinion, using a 1/2" tip on a 5/8" strap would be easier than trying to re-work a 1" tip.
Re: Top Boot Straps
Posted: Sun Feb 16, 2025 4:17 pm
Erik Johnson wrote: ↑Sun Feb 16, 2025 12:06 pm
Agreed!! Good find. I missed your earlier posting.
