Sediment petcock leaking
Posted: Sat Feb 15, 2025 9:28 pm
by LittleTimmy52
I replaced my sediment Bowl and I reused the old petcock after clearing the blockage on the top of it and the petcock is leaking not from the threads but the actual valve part, the spinning part. how might I be able to fix this? I did though disassemble the petcock valve to clean and uninstall and reinstall it but there was no gasket or anything.
Re: Sediment petcock leaking
Posted: Sat Feb 15, 2025 9:31 pm
by LittleTimmy52
Might I add that it also only leaks when the sediment bowl valve is open when I shut the fuel off it quits leaking mind you there's still fuel because if I open the sediment drain valve fuel comes out of the bottom. So it seems it only leaks under a light pressure.
Posted: Sun Feb 16, 2025 11:49 am
by Oldav8tor
A common problem. You could try lapping the valve with a fine abrasive (rubbing compound, etc. - google it) - it didn't work for me so I bought a new petcock. An alternative is to remove the valve and replace it with a brass pipe plug. Not original but it does the job. Normal procedure calls for turning the fuel valve off before draining the sediment bulb. With a plug you can turn the fuel off and remove the plug to drain the bowl - more efficient anyway.
Posted: Sun Feb 16, 2025 12:09 pm
by Erik Johnson
Lap the shut-off valve as previously mentioned and then lubricate it with bar soap.
Posted: Sun Feb 16, 2025 1:41 pm
Ivory bar soap.
Posted: Sun Feb 16, 2025 2:43 pm
by JTT3
Do not be aggressive with lapping or you’ll screw the pooch & create a bigger leak on & off.
Posted: Sun Feb 16, 2025 3:56 pm
Use tooth paste. I found you can go to far with 400 grit lapping compound.
Posted: Sun Feb 16, 2025 4:06 pm
by Rich P. Bingham
There is an aircraft product called “EZ Turn” that is fuel resistant, meant to lubricate the turning parts of fuel line valves and petcocks. It will stop minor leaks and seepage.
Posted: Sun Feb 16, 2025 4:14 pm
I also use EZTurn BUT be careful to use it sparingly - it will block the orifice !
Posted: Sun Feb 16, 2025 5:02 pm
by Rich P. Bingham
Well said Steve !! “A little dab ‘ll do ya !”
Apply a thin film to the “cone” make sure none gets in the orifice of the valve. It keeps the moving part from seizing, and will stop a minor leak. Three years now, mine turn easily and don’t seep.
Posted: Sun Feb 16, 2025 5:31 pm
by Craig Leach
Hi Lucas,
I use timesaver to lap the valve & for lubricant I picked up a can of G-363 military grade plug valve grease. I believe EZ-Turn is the same spec.
Craig.
Posted: Sun Feb 16, 2025 5:51 pm
by NoelChico
I've lapped several similar fuel valves with timesaver then used EZ turn. They don't leak and turn well. Unfortunately, it only comes in a large 5 oz tube that will take me 5 lifetimes to use. I plan on getting some small bottles (prescription bottles?) and give it to friends on tour. :)
Posted: Sun Feb 16, 2025 8:14 pm
I've done the same Noel - more in a tube than I'll ever use !
Posted: Tue Feb 18, 2025 1:06 am
by Craig Leach
I picked up this @ a swap meet it's about 1/3 full I will never use it all up but don't know anyone that repairs valves other than me.
Craig.
