Stutz Dual Cap Distributor
Posted: Wed Feb 26, 2025 8:16 pm
by Chris Haynes
I just bought a car with a Morton and Brett OHV head on it. The car is set up to use the type of distributor used on four cylinder Stutz and a couple other makes. My distributor is missing and I need a replacement. If you know of one PLEASE let me know.
Re: Stutz Dual Cap Distributor
Posted: Wed Feb 26, 2025 10:50 pm
by Dan McEachern
Contact Tom Van Meeteren- he specializes in early ignition parts and probably has what you need. Just FYI, it is possible to adapt early 4 cyl Jeep cap and rotor to a Stutz ignition. The rotor fits right on the dist cam, but the cap needs some lathe work and a lock ring for the OD to retain the cap on the clips.
Here is the e-mail I have for Tom- he posts on here from time to time.
tsvanmeet@gmail.com
Posted: Thu Feb 27, 2025 9:54 am
by AndyClary
That’s good to know Dan. I got rid of one because the “correct” parts were were really expensive.
Andy
Posted: Thu Feb 27, 2025 11:56 am
by Shannon_in_Texas
Chris, you might find some useful information in this thread:
viewtopic.php?f=2&t=43141&p=348676#p348676
Posted: Thu Feb 27, 2025 10:24 pm
by Dan McEachern
A dusty picture is better than no picture............
Posted: Fri Feb 28, 2025 9:51 pm
by Bob in ohio
Dan- can you post the year of jeep or part number of the distributor cap and rotor that will work with the early Delco unit?
Posted: Fri Feb 28, 2025 10:12 pm
by Dan McEachern
I made this 35 years ago, but pretty sure they are '48 4 cyl Jeep with Autolite IAD series distributor. Cap is a Standard Motor Parts AL35.
The Rotor is a Standard Motor Parts AL85. The rotor is a drop in. The cap needs to be machined to the proper height and to register on the Delco Remy /Stutz housing.
Posted: Sat Mar 01, 2025 2:23 pm
by Mike Penserini
Thank you Dan, This info certainly spares much frustration and dollars finding caps and rotors.
Posted: Sat Mar 01, 2025 7:43 pm
by Bob in ohio
Thanks Dan, I just bought a cap and will try to do the modification.
