Buying or making a pin to secure fan crank shaft pulley
Topic author - Posts: 73
- Last Name: Kriegel
- * REQUIRED* Type and Year of Model Ts owned: 1927 1926
- MTFCA Number: 52627
My pin fell out and is lost Looking in Snyders and MAcs I see the entire assembly for sale but not just the pin Am I blind or does someone see where I can buy just the pin? Another member suggest I fabricate a pin drilling a hole in it I need advice on finding a soft metal of the correct diameter He then suggests using a split pin to secure the fabricated bolt I assume I drill a hole down into the bolt face the length of the bolt to expand it and not through the bolt. Sorry for my ignorance I keep trying to learn from all of you This is a non starter car
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Buying or making a pin to secure fan crank shaft pulley
Dave, let me look see if I have one. If I do you can have it. I am close so you could pick it up if you luke.
Like not luke.
I have a crank pully pin. You can call or txt me.
260-336- six 55 five.
- MTFCA Number: 16175
- MTFCI Number: 14758
This is not in great condition, but it shows how the pin goes. The pulley has a small hole on one side to drive out the pin with a drift, and a larger opposite hole for the pin to pass through. The end of the pin near the larger hole gets a cotter pin, not a roll pin, to keep it in.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Thank you all !! This is why I like repairing and learning Model T's Where else can I put a question out on a Sunday Morning and get so much help and advice in just a few hours !!!!
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
I use a roll pin.
It eliminates the need for a cotter pin which is difficult to install and remove.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- MTFCA Number: 4838
- MTFCI Number: 115
Prefer to use the solid Ford style pin in the crank pulley.
Once had trouble removing a rolled pin, guess the former owner stood on the crank handle at some point. The crank handle ratchet wouldn’t fit well, as that hollow roll pin bent. Sure was hard to get that bent piece of metal out the pulley holes
- First Name: BOB
Must have been a Left Hand Metric Roll Pin
I have had good luck installing and removing the roll pin on mine.
A roll pin came with the after market machined crankshaft pulley I got some time back.
Be_Zero_Be
Be_Zero_Be
- MTFCA Number: 121
- MTFCI Number: 16310
If your new pin isn't secure in the crank, you might wish to knurl the center of it so it will be snug in the crankshaft.
