KW Wood Coilbox
Posted: Fri Mar 14, 2025 1:09 pm
The KW wood coilbox used only in 1913 uses non insulated silver colored stranded wire about 14 AWG. I'm wondering if this type of wire is still available?
Re: KW Wood Coilbox
Posted: Fri Mar 14, 2025 1:52 pm
Original Smith wrote: ↑Fri Mar 14, 2025 1:09 pm
Larry,
It's "buss wire". Tin coated copper wire.
https://www.mcmaster.com/products/bus-wire/
https://sea-wire.com/aa59551/
OOPS... missed the part about it being
stranded wire.
Re: KW Wood Coilbox
Posted: Fri Mar 14, 2025 2:01 pm
Couldn't find it bare. 14 AWG bare stranded hookup wire
You may need to strip the wire 14 AWG marine grade hookup wire
This listed the best match & at Home Depot too
https://www.homedepot.com/p/Ancor-Marin ... /316303205
Looks like purple is on-sale other colors are higher
Re: KW Wood Coilbox
Posted: Sun Mar 16, 2025 12:22 pm
Interesting. That is what I did, however, I was unaware of marine grade stranded wire. Thanks for the information !
Re: KW Wood Coilbox
Posted: Wed Mar 26, 2025 4:12 pm
I had to go to a marine supply store to find it. It is not twisted but is the correct wire I was looking for. All that needs to be done is the insulation stripped off, and then twisted. #14 AWG.
Re: KW Wood Coilbox
Posted: Wed Mar 26, 2025 6:05 pm
You might ned to check the number of strands before twisting it.
