Some reassembly required
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Jun 24, 2019 9:46 pm
Now I have to get it put back together. :D
Steve Hughes
Last Name: Hughes
MTFCA Number: 216
MTFCI Number: 23070
Re: Some reassembly required
Post by Steve Hughes » Mon Jun 24, 2019 9:59 pm
Nothing like the incentive program. I have confidence you can do it.
Joe Reid
First Name: Joe
Last Name: Reid
MTFCI Number: 22088
Post by Joe Reid » Thu Jun 27, 2019 11:08 pm
Did you rebuild your engine? Are you driving your 15 or your 23?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Jun 27, 2019 11:39 pm
It will be the 15 again. The engine is at Mike's in Tulsa, and I'll be going down Monday for another work day. I hope to have it back in the car in a couple of weeks so I can spend August breaking it in and getting ready to go.
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Post by George N Lake Ozark » Fri Jun 28, 2019 2:12 am
I'm curious on how well the scat crank will work for you.
Gonenorth
First Name: Kevin
Last Name: Whelihan
MTFCA Number: 30688
Board Member Since: 2008
Post by Gonenorth » Fri Jun 28, 2019 7:31 am
Steve, you will love the SCAT crank. Engine runs smoother and no more worries about participating in the two-piece lottery.
Joe Reid
First Name: Joe
Last Name: Reid
MTFCI Number: 22088
Post by Joe Reid » Sat Jun 29, 2019 12:10 am
Steve, are you coming up to the Iola Car Show? Sounds good about your 15.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Jun 29, 2019 12:19 am
Hmmm... That's week after next. I hadn't thought about it, but maybe I should head up that way and get out of the heat for a few days.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Jun 29, 2019 10:01 am
Beware on the Scat crank. The front horseshoe bolt comes too close to it, and I think I had to dish the horse shoe a bit too.
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Sun Jun 30, 2019 3:57 pm
It's the rear hose shoe, not the front one...... there's lots of clearance for the front one, I finished my engine up the other day and went through that. Just use a 1" long 5/16" bolt, cut the head off, put it in the center rear horseshoe hole, weld it, then grind the horseshoe as needed. I'ts really easy to see this with the inspection pan off.
With Mike working on your engine he'll take care of it for you.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jun 30, 2019 4:33 pm
Yep, I believe he already did. Last session we got as far as trying to install the main shaft without any runout. When we couldn't do any better than .002" we quit that and did the front axle instead. I'm going back tomorrow with a box of main shafts in case we want to look for a better one.
