Rocky mountain brakes
Posted: Thu Apr 03, 2025 7:35 pm
by jawa
I have a set of small drum Rocky mountain brakes and was wondering if I could use them on a large drum rear end. If so, are there any parts I would need or could I just use the original large drums?
Thank you,
Adam
Re: Rocky mountain brakes
Posted: Thu Apr 03, 2025 8:00 pm
by Ed Fuller
No.
Small drum Rocky Mountain brakes will not fit on a large drum axle.
The diameter of the special drum used for the small drum brakes are a different outer diameter than the Ford large drum brake drum.
Also, the Rocky Mountain mounting brackets are different for the small drum and large drum due to the different style radius rods used on the two different axles.
Posted: Thu Apr 03, 2025 8:12 pm
by jawa
Ok. Thank you
Posted: Mon Apr 07, 2025 12:02 pm
The so called Rocky Mountain brakes, are not really that! They were patterned after a 1926 AC brake. I know. I was there.
