Timing Cover Alignment Tool
Posted: Sun Apr 20, 2025 9:29 am
by BRENT in 10-uh-C
Does/Are any vendors selling Bob's style of alignment tool? If so, who is selling them??
TIA
Re: Timing Cover Alignment Tool
Posted: Sun Apr 20, 2025 10:19 am
by Line_Noise
Ebay seller "burnzoil" makes and sells them. He has also sold in the classifieds here, but it has been a while and I forget his username.
Posted: Sun Apr 20, 2025 10:24 am
No idea, but I think any decent machine shop could make a simple alignment tool. Picture a round piece of metal exactly the diameter of a timer cover, with a hole exactly in the center that slips onto the end of the cam shaft.
Posted: Sun Apr 20, 2025 10:28 am
by Moxie26
Lang's ran out of stock tools ????
Posted: Sun Apr 20, 2025 11:15 am
by Dan Hatch
Posted: Sun Apr 20, 2025 12:42 pm
by Ed Fuller
The late Bob Scherzer reproduced the KR Wilson tool.
Posted: Sun Apr 20, 2025 12:53 pm
by Rich Bingham
Gene French makes them.
Posted: Sun Apr 20, 2025 4:20 pm
by BE_ZERO_BE
Posted: Sun Apr 20, 2025 7:35 pm
by BRENT in 10-uh-C
Steve Jelf wrote: ↑Sun Apr 20, 2025 10:24 am
Thanks Steve. I have two of the aluminum ones that index on the cam seal flange but I am finding those are hit/miss on whether they index correctly. I had a large one from years ago that Bob had made but it appears it is now MIA. I may just machine a piece of aluminum that will index off of that little one and the larger ring will slide over the small one.
Thanks everyone.
Posted: Sun Apr 20, 2025 8:25 pm
BRENT in 10-uh-C wrote: ↑Sun Apr 20, 2025 7:35 pm
Thanks everyone.
Those are the ones Langs sells that used the seal area. My preference would be the KRW style. I too was going to suggest Gene French. Pretty sure he makes the style that indexes off the machined recess the timer fits into.
Posted: Sun Apr 20, 2025 9:04 pm
by KurtM
How necessary are these tools? What happens if you replace a timing gear without one?
Posted: Sun Apr 20, 2025 10:37 pm
You have a very good chance of either "roller bounce" or in the case of distributor gear mesh, a "not good" scenario ! The only one that actually centers the timing cover IS the large diameter tool !
Posted: Mon Apr 21, 2025 9:16 am
by KurtM
Thanks Steve, anyone else? I ask because I just changed the timing gear on my '23 Runabout without the centering tool 'cuz I didn't have one. The car's mostly original, sporting a New Day timer. My buddy put his together without the tool a while back and his car runs great, is why I went ahead instead of ordering a tool and waiting a week to get my car back on the road. He had a roller, and then switched to a flapper type of timer, if I have the terms anywhere near correct or at least understandable.
Posted: Mon Apr 21, 2025 11:42 am
by Rich Bingham
Kurt, I may be wrong about this, but I think the configuration of the New Day is such that it “forgives” the timing cover being less than perfectly centered over the camshaft.
At least that was my experience 63 years ago, when, as a dumb kid I found I couldn’t keep the factory roller timer operating properly - switching to a New Day, problem solved ! At the time, I didn’t know the timing cover had to be centered over the camshaft with a special tool.
Posted: Mon Apr 21, 2025 2:23 pm
I agree that the design of the New Day should make it immune to the slight cover misalignment that sometimes means trouble for a roller timer. I've used New Day for many years, and my lack of a centering tool has not been a problem. Should we all have one? Sure. Better safe than sorry.
Posted: Tue Apr 22, 2025 10:18 am
Posted: Wed Apr 23, 2025 10:15 am
by jab35
I made one from an original Ford timer by turning a block of maple to a moderate press fit in the case with original contact ring removed, and bored a hole to fit camshaft. Used it once with good result, fwiw. jb
