Front spring question
Posted: Tue May 06, 2025 7:54 am
by LittleTimmy52
I have a 17, it is to my knowledge that the front should have 6-7 leafs and the later models have 8-9, mine has 9, should I just take the top 2 off to make it 7? Or do I have to get a new spring which in that case I'm leaving it. Additionally the u bolt looking things that hold the spring up on the t, what's it called, I need to get new ones since the threads there are gone. Side question, radius rod is rust welded in the perches, how can I get it out without turning the perches?
Re: Front spring question
Posted: Tue May 06, 2025 11:19 am
by Daisy Mae
* a 9 leaf front spring is a TT.
* IF my 45 yr ago memory is correct, the difference between the 7 leaf car and the 9 leaf spring on my TT was the top and third leaf down...but that's memory, not on certainty...take with a grain of salt if you remove.
* the U-bolt frame attachments, if the threads are shot, replace...don't take risks with compromised parts that are critical to the safety of you or the car
* there are many ways to remove rust welded parts, this topic alone can elicit long & varied responses, but a bit of caution here. If your rod threaded ends & ball, as well as your perches are in good shape, leave them be. There have been more radius rods and spring perches destroyed simply attempting to remove them for no reason. Not to mention early style perches and rods are pretty much made of unobtanium now. Better to assess what your actual repair needs are before you attempt disassembly that may not be required.
Posted: Tue May 06, 2025 2:56 pm
by LittleTimmy52
The ball is quite malformed, I wanted to remove it to see what k can do, I think there's a weld on replacement, also it should be the earlier style (I think) but I got the more common later style with the lower supports, actually one is loose in the bracket, if I tighten it up it becomes a tad shorter of the other one, what should I do about that, I didn't remove the rod, but from what I can see it looks fine thread wise on the rod.
Posted: Tue May 06, 2025 6:14 pm
Lucas, the U bolts for the early type spring mounting are not available new, so you will have to source some good used ones. To use them on a 9 leaf spring would require them to be 1/2' longer than standard. I have never seen such U bolts. A photograph may help identifying just what you have. Perhaps they are aftermarket hand made items.
Posted: Tue May 06, 2025 10:20 pm
by LittleTimmy52
Can I use new bolts on the early one? I plan on sourcing am early one, but I need a plan b.
Posted: Tue May 06, 2025 11:00 pm
by Craig Leach
Hi Guys,
I'm one of the last people to ask about originality on Model T's but this is the front spring from a TT chassis I purchased some years ago.
Note that two leaf's are doubled up, it's 11 leaf's if you remove the doubled ones it's 9 leaf's.
Craig.
Posted: Fri May 09, 2025 8:17 am
by LittleTimmy52
I don't know if the pictures are good, but as yok can see the ball is bad, I tried to get one of the threads its bad on the wishbone on a side the the lower half with the tape o font know how to adjust because I e is loose but if I tighten it it is shorter than the other. The u bolt may be stripped on one side but since I'm taking 2 leafs off, the damage will be raided just above the nut and I can re use it since the threads below are fine. Thanks everyone who replied this far I appreciate any help I can get.
Posted: Fri May 09, 2025 8:18 am
by LittleTimmy52
This I e didn't send
Posted: Fri May 09, 2025 10:21 am
by love2T's
When you say "new bolts" I don't know what you mean other than totally modern U bolts which first won't fit right and second look horrible. Try Chaffins or Langs they often have good used early Engine Mounts a.k.a. Front Spring Clamps and maybe even an NOS
Posted: Fri May 09, 2025 7:48 pm
by LittleTimmy52
I'm reusing the old ones because I removed 2 leafs and the damaged part would be above the nut do its still useable.
I thought I needed a new one until I realized the spot of the damage was less than the width of the leafs removed therefore it will stick up more and the nut would pass it.
