Parts for Rocky Mountain Brakes
Posted: Fri May 09, 2025 10:59 pm
by JBog
Part of my rocky mtn brakes came off and vanished into the ether the other day. I don’t need a whole new set, but some of the parts that went missing on my country drive. Where can I get just some replacement parts?
Re: Parts for Rocky Mountain Brakes
Posted: Sat May 10, 2025 12:39 am
by JBog
I think I found his phone numbers. Does he have an email? I'd like to send pictures.
Posted: Sat May 10, 2025 10:55 am
by ModelTWoods
This came with the brochure and installation instructions with my set, but I bought them several years, ago. Info, may or may not, be current:
Rocky Mountain Brake Co., Inc. , 39810 Bella Vista Road , Temecula, CA. 92592. Mailing address: P.O. Box 890912 , Temecula, CA. 92589. E-mail: budwilliams@ rockymtnbrakes.com . Phone: (951) 440-1451 FAX: (951) 694-9932
Posted: Sat May 10, 2025 11:00 am
The parts from Rocky Mountain Brake Co. in Temecula will work fine for the brakes he manufactures. Some of the older R.M. brakes are different, so if you need parts for them, you might need to check the swap meets.
Posted: Sun May 11, 2025 12:55 pm
What parts went missing? Maybe someone can offer suggestions on work arounds.
Posted: Sun May 11, 2025 1:46 pm
Check with Chaffin's Garage - I believe they carry some replacement parts.
Posted: Sun May 11, 2025 5:59 pm
by JBog
Mark Gregush wrote: ↑Sun May 11, 2025 12:55 pm
This part fell apart on my drivers side.
Posted: Sun May 11, 2025 6:17 pm
Your adjusting nut is upside down. The ridges keep the nut from backing off.
Posted: Sun May 11, 2025 8:03 pm
by JBog
Thanks! I’ll fix that one. That’s probably how I lost the other side.
Posted: Sun May 11, 2025 8:24 pm
JBog wrote: ↑Sun May 11, 2025 8:03 pm
Yep. If cotter pinned correctly, the rod should have stayed attached.
You should have lost the nut, 2 washers & a spring only.
Posted: Sun May 11, 2025 11:08 pm
by JBog
speedytinc wrote: ↑Sun May 11, 2025 8:24 pm
I also lost the bushing or whatever it is that bolt passes through.
Posted: Mon May 12, 2025 2:27 pm
Don't recall seeing that bushing on other setups? Otherwise, take the other side apart and make a trip to ACE or other hardware store and match the spring up and other missing nuts and washers as needed. The adjusting nut might be a little harder but longer type nut with bevels ground would work like the sample from the other side work, even a steel one. The sleeve would just be a piece of steel tube with hole drilled through it.
Posted: Wed May 14, 2025 12:00 pm
Mark Gregush wrote: ↑Mon May 12, 2025 2:27 pm
Or even a solid piece of steel rod with a hole drilled through it.
Posted: Wed May 14, 2025 1:16 pm
I own three T's with original Rocky Mountain brakes, and I've never had a part fall off!
Posted: Thu May 22, 2025 12:12 am
by Craig Leach
Hi Jason,
Have you been able to get the parts you need for your RM brakes? If not Mc Master-Carr has L bolts in 3/8 x 16 in many lengths of both
dimensions in Tensile strengths of 58,000-120,000 lb.& thread length. Look under Hook anchors for concrete. The adjuster nut can be made
from a 3/8" coarse rod coupler, the swivel tube can be made of any tubing of the correct Diameter & every thing else is hardware nuts, washers
spring & cotter pins.
Craig.
Posted: Thu May 22, 2025 10:17 am
by JBog
Craig Leach wrote: ↑Thu May 22, 2025 12:12 am
Hi Jason,
Craig.
I have! I appreciate your help!
Buds daughter, Suzanne, has taken over the business and it’s now based in stevensville Montana! She is responsive to emails and very helpful.
They have email, but I don’t know if they want that posted.
Posted: Thu May 22, 2025 11:32 am
by Craig Leach
Hi Jason,
Good to hear you got what you needed. Please ask Susanne if it's OK to post that contact info I'm sure here will be people that need parts in the
future or at least let us know which venders have access to them.
Craig.
