cam bearings
tman12
First Name: john
Last Name: Willams
MTFCI Number: 20566
cam bearings
Post by tman12 » Thu Jun 27, 2019 11:08 am
Hi From Iowa: I started to install my new 280 cam & found that I have the wrong frt cam bearing that is not available from main suppliers? At Lincoln last week I was told there may be a new supplier? Des anyone know the scoop & contact? I have also forgotten where to get some red rubber hose for the ac lts? Many Thanks John
Last Name: Gregush
Re: cam bearings
Post by Mark Gregush » Thu Jun 27, 2019 11:14 am
Re the front bearing; Have you contacted the suppliers yourself? Try Chaffin's.
1921 Huckster
tman12
First Name: john
Last Name: Willams
MTFCI Number: 20566
Re: cam bearings
Post by tman12 » Thu Jun 27, 2019 4:24 pm
I have contacted all the main suppliers & the man that made the new cam bearings has had problems with the foundery that supplied the blanks & cannot supply at this time. I need to find someone with an extra set or maybe someone else is now making them? HELP John - PS Glen C is the one who told me the sad story!
John bevardos
Last Name: bevardos
Re: cam bearings
Post by John bevardos » Thu Jun 27, 2019 5:07 pm
Hi John,
I believe that Gene French sells re-babbited bearings. Might try to reach out to him.
John
Kerry
Last Name: van Ekeren
Re: cam bearings
Post by Kerry » Thu Jun 27, 2019 5:35 pm
The longer early bearings can be turned down shorter for the later front bearing, done it many times to have a good fit for shaft end play.
Last Name: VanOoteghem
Re: cam bearings
Post by Jerry VanOoteghem » Thu Jun 27, 2019 9:54 pm
If the usual T suppliers don't have the red rubber hose for your lights, then try Restoration Supply Co. They have 2 grades I believe. One is just like the original stuff, (supposedly), and the other is also pretty nice.
tman12
First Name: john
Last Name: Willams
MTFCI Number: 20566
Re: cam bearings
Post by tman12 » Fri Jun 28, 2019 8:26 am
Many Thanks to all you Great Guys & your Good suggestions - This the Best Group Of People Always willing to Help Us T Lovers With our problems! John
