Cleaning out a Fuel Tank
Posted: Mon Jun 02, 2025 8:52 pm
by Jugster
I’m dealing with a clogged and varnished-up gas tank. The few local establishments that clean and coat gas tanks charge about $600.00 which, to me, feels awfully pricey. Is there a do-it-yourself bottle of magic chemical that I can pour into the tank, agitate the tank, pour the magic chemical out and consider the tank sufficiently clean?
Re: Cleaning out a Fuel Tank
Posted: Mon Jun 02, 2025 8:59 pm
I have had great success with the POR tank treatment kit. The initial clean out involved a couple of kilos of roofing TEK screws and a concrete mixer. The screws went in the tank, and the tank went in the mixer. This gives a mechanical clean out rather than chemical. The resultant surface is squeeky clean and somewhat abraded for a good bond for the kit components.
Posted: Tue Jun 03, 2025 1:40 am
by Dodge
If its mostly varnish/shellac, the solvent for it is denatured alcohol. I have poured in a gallon and kept turning the tank over and over for
about 10days. It also helps to shake it in between turning it.
After it loosened everything up I used a pressure washer inside it to get it clean.
Unfortunatly the lovely State of California has now banned denatured alcohol for sale. I'm glad I have a stash of the stuff.
Posted: Tue Jun 03, 2025 4:02 am
by brendan.hoban
I had a problem with my motorcycle tank, crud and rust buildup.
I used to containers (about 5 ounces) of citric acid, cost, about US$10.00 with hot water, filled the motorcycle tank and left it in the sun in the afternoon and then overnight.
I poured out the result next day (it's ecologically harmless) and what a brown sludge it was. The tank was clean and shiny inside, even the nether regions only seen with a probe camera.
No further treatment was required as a BSA Bantam motor cycle is a two stroke needing 5% oil mixture, proof against further rust.
Posted: Tue Jun 03, 2025 11:14 am
Bob - why not contact Kevin Prus & purchase a new round tank & be done with the monkey-motion ?
Posted: Tue Jun 03, 2025 12:34 pm
by Russ T Fender
I thought Kevin was just making the oval tanks. I bought one from him last year.
Posted: Tue Jun 03, 2025 7:58 pm
by Racer_22
I have both round 13-20 and oval available
Kevin Prus
Posted: Wed Jun 04, 2025 7:50 am
by varmint
We used a couple gallons of vinegar and some rocks for cleaning in stage 1.
After cleaning, rinsing it out we used the POR method.
Posted: Wed Jun 04, 2025 3:33 pm
The recommendations of cleaning are for different needs.
Your request for for "varnished tank" not "rusted tank".
PUR-15 Metal Prep, Evaporust, White (Cleaning) Vinegar, etc are for rust removal
Chemicals that are known to dissolve gas tank varnish ( White (Cleaning) Vinegar, denatured alcohol, Acetone, MEK, Sea Foam etc)
The you need to dispose of the residue safely.... Cleaning time + effort + safe disposal only to find that the tank had a rust hole that was sealed by the varnish... then you'll buy a new tank.
Posted: Wed Jun 04, 2025 7:49 pm
by NoelChico
If denatured alcohol works so well, why not purchase a couple of gallons of E-85 fuel (55-85% alcohol). Slosh it around inside for a few days. It should work as well and is way cheaper than denatured alcohol at the store.
Posted: Wed Jun 04, 2025 11:25 pm
I can think of hundreds of reasons to solder up a rust hole in an otherwise clean tank, most of them being Dollars. One of the tanks I treated to a POR kit had a couple of pin holes. POR said they would be sealed by their process. I took no chances and soldered them anyway.
