Play in the steeering wheel
Posted: Thu Jun 12, 2025 7:01 pm
When I removed the gear case cover and moved the steering wheel, I saw the pins move from side to side. I removed the steering shaft and with some difficulty removed 2 of the pins. I cleaned the pins, gears, and pin holes with cleaner to get all the grease off them. I measured the following:
Gear hole diameters: .378, .380 and .380 inches.
Pin diameters: .374 inches.
Pin hole diameters . .370 inches.
I can not see how the pins were moving with these measurements. I have been unable to remove one pin with a punch and hammer. The other two came out, with difficulty.
Does anyone know what the holes for the pins, the pins diameter, and the holes in the gears should measure.
Also, what should I order to fix this problem, other than a new Model T?
I thank you for any help I get.
