Flywheel ring gear heads up
Posted: Mon Jun 23, 2025 3:47 pm
by Dan Hatch
I am in the process of rebuilding some flywheels. Installing new ring gears, like I have done many times before.
Tried to install a new brass screw in a hole about halfway through and would not start. Turns out some chinaman missed tapping it. This is second one I have seen in a couple years. Not sure of the age of this ring gears, but watch out guys.
Re: Flywheel ring gear heads up
Posted: Mon Jun 23, 2025 6:00 pm
by Henry K. Lee
Sent the memo to my cousin One Hung Low and he is on it! He says....,"Capitalist B@sT@rds want everything perfect".
Posted: Mon Jun 23, 2025 7:38 pm
by Dan Hatch
I should have known!
Posted: Mon Jun 23, 2025 8:02 pm
Is the area of the threads to hard to re-tap?
I ask because I have one with the wrong bolt pattern.
Posted: Mon Jun 23, 2025 8:31 pm
by Dan McEachern
Be aware there are ring gears out there wit the original #14-24 threads and also i believe 1/4-24 threads. This came about around 10 years ago due to some supplier mix up so make sure you use the correct screws. Snyders has screws with both threads available in their catalog as do most other parts suppliers. The ring gears are soft enough to retap or redrill if you need to.
Posted: Mon Jun 23, 2025 10:14 pm
by Dan Hatch
All the new I have run into are 1/4” x24.
Posted: Mon Jun 23, 2025 11:46 pm
by ModelTWoods
Henry K. Lee wrote: ↑Mon Jun 23, 2025 6:00 pm
Won Hung Low also said, " Not to mention your Supreme Leader is trying to screw us China men with high tariffs."
Posted: Tue Jun 24, 2025 7:43 am
by browning
He is the brother in law of the QC manager, Som Ting Wong.
