ALUMINUM TIMING GEAR SOURCE
Posted: Mon Jul 01, 2019 12:56 pm
by John Dow
Hi Folks. I'm on a search for an aluminum .005 oversize timing gear. I understand the gear manufacturer for the usual parts dealers is serionuisly behind in production. Langs estimates a lengthy wait for order fulfillment. Got any suggestions??
Re: ALUMINUM TIMING GEAR SOURCE
Posted: Mon Jul 01, 2019 2:28 pm
Check with Bobs Antique auto parts. He had T parts I needed when the others were out of stock.
Posted: Mon Jul 01, 2019 4:21 pm
by SurfCityGene
Dan McEachern Gear works in Alameada makes the best timing gears for a Model T. His Bronze one is amazing! I believe he supplies many vendors possibly.
Posted: Mon Jul 01, 2019 5:51 pm
by John Dow
Thanks Gene, I am looking to replace my Dan McEachern brass gear because it is oversized. I believe I'm running and original steel crank gear that is worn out or maybe the last babbit job was out of whack. Anyways I need a larger gear to get rid of the slop--the rattle is driving me crazy!!!
Posted: Mon Jul 01, 2019 9:49 pm
by John Dow
Sorry, my Dan Mc is UNDERSIZED.
Posted: Mon Jul 01, 2019 9:58 pm
by Joe Bell
I have a bunch of the old fiber gears that are oversize. to bad you where not closer you could take your pick for free!
Posted: Mon Jul 01, 2019 10:55 pm
Posted: Tue Jul 02, 2019 1:33 am
by Dan McEachern
If you need an oversize cam gear, I have a pretty good assortment of them in stock. Not sure what you mean that your bronze gear is undersize unless it was a special that we intentionally cut undersize for some reason in the past. My e-mail is dmcgearsatyahoodotcom. replace the at and dot with the usual. Dan
