Connecting Rod bolts?
Posted: Mon Sep 08, 2025 4:15 pm
by Dan Hatch
Anyone know the modern part number for the connecting rod bolts. I think it is a Chevy rod bolt, which one? Thanks Dan
Re: Connecting Rod bolts?
Posted: Mon Sep 08, 2025 5:28 pm
Dan Hatch wrote: ↑Mon Sep 08, 2025 4:15 pm
Posted: Mon Sep 08, 2025 5:33 pm
Small block V8 chevy. 350 on down.
Posted: Mon Sep 08, 2025 5:46 pm
by Dan Hatch
Thanks John, I need about 10 sets. Dan
Posted: Mon Sep 08, 2025 6:18 pm
Dan Hatch wrote: ↑Mon Sep 08, 2025 5:46 pm
That's what I use. Much improved over stock type.
You are aware the knurled portion has to be taken down a little? Then you have a "pin" tight fit.
Posted: Mon Sep 08, 2025 7:09 pm
by Dan Hatch
Yes, just was not sure of the use. Dan
Posted: Mon Sep 08, 2025 7:24 pm
by NoelChico
Most engine rebuilders use new bolts and discard the ones taken out of the Chevys. Since we don't torque near as far, I ask the shops or local mechanics for their used bolts. I'm cheap!
Posted: Sun Sep 14, 2025 3:54 am
by BobUkPipedream
Beware of some of the bolts that were being sold in the blue and white Model T packs. Mine went to torque once, then stripped on the second attempt. Ended up using the original bolts again.
