New T for me
Posted: Fri Sep 19, 2025 10:53 pm
It has been over 50 years since I have had my rdstr pickup running and I have driven a model t. I have worked on several for other people and given them parts but failed to work on mine and it need quite a bit of work.
Well thanks to the MTFCA and the cars for sale I bought a 23 couple. Needs some paint and a little work but will be up and running.
Need to rework the electrical to the starter including a frame to engine ground strap , want to put a solenoid on it and a disconnect switch.
Dropped the neutral lever today to check the pawl and it needs replaced but I believe I have a neutral lever in the attic.
A question I have is I have seen where others have glued on a front crank seal to stop leakage.
How is it done and what seal as there is a quite a bit of wash back under the car starting at the front and the inspection cover does not appear to be leaking at the bolts but the seal looks like it has been leaking?
