What's this bolt for?
Posted: Fri Jul 05, 2019 4:44 pm
by Thorlick
I was just searching through my spare parts for some needed bits and found this part.
Here is a normal water inlet I found:
Here is the one I think is unusual.
It has a bump on the inside, the hole is not drilled through.
It has a bolt with what looks like a conduit clamp.
The only thing I can think of is a clamp for the horn wire, what's your guess? Have you ever seen one like this?
TH
Re: What's this bolt for?
Posted: Fri Jul 05, 2019 5:00 pm
by Rich Eagle
Model A's used a bolt there for the generator conduit. Could that be for a Model A?
Posted: Fri Jul 05, 2019 5:38 pm
by Layden Butler
Rich is right, Model A Ford.
Posted: Fri Jul 05, 2019 6:01 pm
by Thorlick
Thanks, I thought I had some sort of rare, unusual aftermarket T part. Instead it is a relatively worthless part from a gooney little known car!
(tongue firmly in cheek)TH
Posted: Sat Jul 06, 2019 4:36 am
by Wayne Sheldon
I am pretty sure I have one of those in my junk boxes if you need another?
Posted: Sat Jul 06, 2019 11:38 am
by Thorlick
Thanks, Wayne, but I don’t wear ear rings!
TH
